Get-SdSnapMirrorPolicyRule
Gets the rules for managing Snapshot retention on the SnapVault secondary storage system.
Syntax
Get-SdSnapMirrorPolicyRule [-SourceStorageSystem] <String> [-SourceStorageSystemVolume] <String> [-DestinationStorageSystem] <String> [-DestinationStorageSystemVolume] <String> [-Session] <String> [-Host] <String>
Detailed Description
Gets the rules for managing Snapshot retention on the SnapVault secondary storage system. Related cmdlets: Set-SdSnapMirrorPolicyRule, Remove-SdSnapMirrorPolicyRule
Name | Description | Required? | Pipeline Input | Default Value |
SourceStorageSystem |
Specifies the primary storage system name containing the source volumes of the SnapMirror relationship for which you want to retrieve the SnapMirror policy rules. IP addresses are not supported. |
true |
true (ByValue, ByPropertyName) |
SourceStorageSystemVolume |
Specifies the source volume of the SnapMirror relationship for which you want to retrieve the SnapMirror policy rules. |
true |
true (ByPropertyName) |
DestinationStorageSystem |
Specifies the secondary storage system name containing the destination volumes of the SnapMirror relationship for which you want to retrieve the SnapMirror policy rules. IP addresses are not supported. |
true |
DestinationStorageSystemVolume |
Specifies the destination volume of the SnapMirror relationship for which you want to retrieve the SnapMirror policy rules. |
true |
Session |
false |
Host |
Specifies the name or IP address of the host on which you execute the operation. The default is your local machine. |
false |
Example 1: Getting SnapMirror policy rule information from the policy for a SnapMirror relationship
PS C:\> Get-SdSnapMirrorPolicyRule -SourceStorageSystem vs1 -SourceStorageSystemVolume src_vol -DestinationStorageSystem vs2 -DestinationStorageSystemVolume dest_vol01 -verbose
Get the SnapMirror policy rules from the policy on the specified relationship.
SnapLabel : daily NumberOfSnapsToKeep: 10 PreserveSnaps : PreserveSnapsSpecified : False WarnThreshold : 0 SnapMirrorPolicy : snapvault_policy SnapLabel : weekly NumberOfSnapsToKeep: 3 PreserveSnaps : PreserveSnapsSpecified : False WarnThreshold : 2 SnapMirrorPolicy : snapvault_policy SnapLabel : mothly NumberOfSnapsToKeep: 4 PreserveSnaps : PreserveSnapsSpecified : False WarnThreshold : 3 SnapMirrorPolicy : snapvault_policy The getting SnapMirror policy rules operation is successful.
