SnapCenter 5.0 cmdlets
Get-SmBackupReport
Gets reports about backup operations based on the options you specify.
Syntax
Get-SmBackupReport [-FromDateTime]  <DateTime>  [-ToDateTime]  <DateTime>  [-Backup]  <String>  [-Status]  <String>  [-Policy]  <String>  [-ResourceGroup]  <String>  [-Resource]  <String>  [-HostName]  <String>  [-Plugin]  <PluginCode>  [-BackupId]  <Int64>  [-JobId]  <Int64>
Detailed Description
Gets reports about backup operations based on the options you specify. You can specify whether you want to get details about a specific backup or a summary of all backups performed using a SnapCenter instance. For any integer value provided for date, value is taken as 1/1/0001 12:00 AM.
Name Description Required? Pipeline Input Default Value
FromDateTime
Specifies that you want to get backup operations reports for backups run between a specified day and time. This option provides the start date and time. You can specify the date and time using any date and time format string. For example, "2/2/2015 8:52PM". If the cmdlet is run from the remote computer, the output will be shown based on the SnapCenter Server time zone.
false
false
ToDateTime
Specifies that you want to get backup operations reports for backups run between a specified day and time. This option provides the end date and time. You can specify the date and time using any date and time format string. For example, "2/2/2015 8:52PM". If the cmdlet is run from the remote computer, the output will be shown based on the SnapCenter Server time zone.
false
false
Backup
Specifies that you want to get a detailed backup report for the given backup.
false
true (ByPropertyName)
Status
Specifies that you want information about backup jobs with a specified status. Valid values are: completed, failed, warning, and canceled.
false
Policy
Specifies that you want reports about backup jobs associated with a specified policy.
false
ResourceGroup
false
Resource
Specifies the resource for which you want backup reports.
false
HostName
Specifies the name of the host on which the backup was taken.
false
BackupId
ID of the backup for which to get a report.
true
JobId
ID of the backup job for which to get a report.
true
Plugin
Specify the plug-in code to generate the report. For custom plug-ins, specify the custom plug-in name for example, hana, mysql.
false
Example 1: Getting a backup report for a date range
 Get-SmBackupReport -FromDateTime "1/29/2015" -ToDateTime "2/3/2015"
This example syntax gets a report on backups from January 29th 2015 to February 3rd, 2015.
SmBackupId   : 113
SmJobId  : 2032
StartDateTime: 2/2/2015 6:57:03 AM
EndDateTime  : 2/2/2015 6:57:11 AM
Duration : 00:00:07.3060000
CreatedDateTime  : 2/2/2015 6:57:23 AM
Status   : Completed
ProtectionGroupName  : Clone
SmProtectionGroupId  : 34
PolicyName   : Vault
SmPolicyId   : 18
BackupName   : Clone_SCSPR0019366001_02-02-2015_06.57.08
VerificationStatus   : NotVerified
PluginCode   : SCC
PluginName   : hana
PluginDisplayName: SAP HANA
JobHost  : R60618C4A79V1
SmBackupId   : 114
SmJobId  : 2183
StartDateTime: 2/2/2015 1:02:41 PM
EndDateTime  : 2/2/2015 1:02:38 PM
Duration : -00:00:03.2300000
CreatedDateTime  : 2/2/2015 1:02:53 PM
Status   : Completed
PolicyName   : Vault
SmPolicyId   : 18
BackupName   : Clone_SCSPR0019366001_02-02-2015_13.02.45
PluginCode   : SCO
PluginName   : Oracle Database
PluginDisplayName: Oracle Database
Example 2: Getting a backup report for a dataset and status type
 Get-SmBackupReport -Status completed -Dataset Secondary
This example syntax gets a report on all backups for dataset "Secondary" that have the "Completed" status.
SmBackupId   : 24
SmJobId  : 310
StartDateTime: 1/12/2015 8:50:49 AM
EndDateTime  : 1/12/2015 8:50:48 AM
Duration : -00:00:00.6900000
CreatedDateTime  : 1/12/2015 8:51:05 AM
Status   : Completed
ProtectionGroupName  : Secondary
SmProtectionGroupId  : 5
PolicyName   : Vault
SmPolicyId   : 18
BackupName   : Secondary_SCSPR0019366001_01-12-2015_08.50.49
PluginCode   : SCC
PluginName   : hana
SmBackupId   : 52
SmJobId  : 585
StartDateTime: 1/15/2015 6:49:07 AM
EndDateTime  : 1/15/2015 6:49:21 AM
Duration : 00:00:13.8370000
CreatedDateTime  : 1/15/2015 6:49:18 AM
Status   : Completed
PolicyName   : Vault
SmPolicyId   : 18
BackupName   : Secondary_SCSPR0019366001_01-15-2015_06.49.08
PluginCode   : SCO
Example 3: Getting a detailed backup report
 Get-SmBackupReport -BackupName Secondary_SCSPR0019366001_01-15-2015_06.49.08
Get a detailed backup for the backup "Secondary_SCSPR0019366001_01-15-2015_06.49.08".
BackedUpObjects  : {TestDB1, TestDB2, TestDB3, TestDB4...}
FailedObjects: {}
BackupType   : Full Backup
IsScheduled  : False
SmBackupId   : 52
SmJobId  : 585
Status   : Completed
PolicyName   : Vault
SmPolicyId   : 18
PluginCode   : SCO
