SnapCenter 5.0 cmdlets
Get-SmCompatibilityFile
Obtains the latest version of the compatibility file from the NetApp Support Site.
Syntax
Get-SmCompatibilityFile [-Auth]  <String>
Detailed Description
Obtains the latest version of the compatibility file from the NetApp Support Site. The compatibility file contains information about the latest supported SnapCenter and plug-in versions. SnapCenter uses this information to identify when component upgrades are available.
Name Description Required? Pipeline Input Default Value
Auth
Specifies the authorization token. This is used for executing this cmdlet in scheduled jobs.
false
false
Example 1: Gets the latest compatibility file
This example syntax retrieves the latest compatibility file from the NetApp Support Site, and displays the version of the compatibility file now deployed on your system.
Compatibility file version: 1.0.8
