Get-SmRepositoryConfig
Displays the repository configuration information.
Syntax
Get-SmRepositoryConfig [-SMSbaseUrl] <String>
Detailed Description
Name | Description | Required? | Pipeline Input | Default Value |
SMSbaseUrl |
Specifies the SnapCenter Server base URL. The base URL includes the name or IP address of the SnapCenter Server, and, if the remote system is in a different domain from that of the SnapCenter Server, the domain name. For example: https://SNAPCENTER_SERVER_NAME/DOMAIN_NAME. |
false |
true (ByPropertyName) |
Example 1: Displaying the MySQL repository details
This example syntax displays the MySQL repository details.
ActiveRepository : 10.236.221.0 ReplicationServers : 10.236.221.0,10.236.221.34 ReplicationStatus : Healthy ReplicationIssues : LastSwitchoverTime : 4/28/2017 7:11:10 AM
Example 2: Displaying MySQL repository details from a remote host to SnapCenter using a base URL
Get-SmRepositoryConfig -SMSbaseUrl https://10.236.221.75:8146/
This example syntax displays the MySQL repository details from a remote host to SnapCenter using the specified base URL.
