SnapCenter cmdlets
Get-SmVerificationServer
Gets information about existing verification servers.
Syntax
Get-SmVerificationServer [-Names]  <String>
Detailed Description
Gets information about existing verification servers. You can get information about specific servers, or all SnapCenter verification servers.
Name Description Required? Pipeline Input Default Value
Names
Specifies the names of the verification server about which you want to get information. If you omit the Names parameter, you get information about all SnapCenter verification servers.
false
true (ByPropertyName)
Example 1: Getting information about a specified verification server
 Get-SmVerificationServer -Names mva-s51, mva-s51/instance1
This example syntax gets information about a specified verification server.
HostName: MVA-S51.mva.gdl.mycompany.com
PlugIn  : SnapManager for SQL
UseDriveLetterIfAvail   : True
DefaultMountPointFolder : c:\abc
MaxJobCount : 1
Description :
EndpointURI : http://localhost:809/SqlManagementService
PluginVersion   :
DefaultMountPointFolder : c:\temp
MaxJobCount : 1
Description :
PluginVersion   :
Example 2: Getting information about all SnapCenter verification servers
This example syntax gets information about all available verification servers.
MaxJobCount : 1
Description :
PluginVersion   :
HostName: MVA-S57-VM2.mva.gdl.mycompany.com
MaxJobCount : 1
Description :
EndpointURI :
PluginVersion   :
MaxJobCount : 1
Description :
PluginVersion   :
MaxJobCount : 1
Description :
PluginVersion   :
