Invoke-SmTechRefreshPrimaryStorage
Perform storage tech refresh of host.
Syntax
Invoke-SmTechRefreshPrimaryStorage [-HostName] <String> [-IsDryRun] <Boolean> [-ChangedNDVMapping] <Hashtable[]>
Detailed Description
Name | Description | Required? | Pipeline Input | Default Value |
HostName |
Specify the host name on which storage refresh has to be done. |
true |
true (ByPropertyName) |
IsDryRun |
Specify whether you want to perform a dry run to find the list of resources for which storage has changed. By default, the value of dry run is set to true. |
false |
True |
ChangedNDVMapping |
Specify the list of Non Data Volumes(NDV) mapping if NDV resource is being migrated from one set of volumes to another set. You must provide the NDVs mapping in a hashtable, and it must contain the OldVolumePath and NewVolumePath. For example,@{"OldVolumePath"="SVM1:/vol/myVol1";"OldVolumePath"="SVM2:/vol/myVol1_new"},@{"OldVolumePath"="SVM3:/vol/myVol2";"OldVolumePath"="SVM4:/vol/myVol2_new"} You can include comma-separated values for multiple NDVs mapping. |
false |
Example 1: Storage tech refresh of host.
Invoke-SmTechRefreshPrimaryStorage -HostName host.mva.gdl.netapp.com -IsDryRun 0
Initiating storage tech refresh.. Name: Tech refresh of storage in host 'host.mva.gdl.netapp.com' Id : 984 StartTime : 10/26/2023 5:02:14 AM EndTime : 10/26/2023 5:02:14 AM IsCancellable : False IsRestartable : False IsCompleted : False IsVisible : True IsScheduled : False PercentageCompleted : 100 Description : Status : Running Owner : Error : Priority: None Tasks : {} ParentJobID : 0 EventId : 0 JobTypeId : 52 ApisJobKey : ObjectId: 0 PluginCode : NONE PluginName : NONE HostId : 0 RoleId : JobIds : {} ScsJobId: Invoke-SmTechRefreshPrimaryStorage Completed
This example does a tech refresh of the storage in the host.
Example 2: Storage tech refresh of host.
Invoke-SmTechRefreshPrimaryStorage -HostName host.mva.gdl.netapp.com -IsDryRun 0 -ChangedNDVMapping @{"OldVolumePath"="SVM1:/vol/myVol1";"NewVolumePath"="SVM2:/vol/myVol1_new"},@{"OldVolumePath"="SVM3:/vol/myVol2";"NewVolumePath"="SVM4:/vol/myVol2_new"}
This example does a Tech refresh of storage in the host.
