Remove-SdSnapMirrorPolicyRule
Removes the rules from the SnapMirror policy associated with the SnapVault relationship.
Syntax
Remove-SdSnapMirrorPolicyRule [-SourceStorageSystem] <String> [-SourceStorageSystemVolume] <String> [-DestinationStorageSystem] <String> [-DestinationStorageSystemVolume] <String> [-SnapMirrorLabel] <String[]> [-Session] <String> [-Host] <String>
Detailed Description
Removes the rules from the SnapMirror policy associated with the SnapVault relationship. Related cmdlets: Set-SdSnapMirrorPolicyRule, Get-SdSnapMirrorPolicyRule
Name | Description | Required? | Pipeline Input | Default Value |
SourceStorageSystem |
Specifies the primary storage system name containing the source volumes of the SnapMirror relationship for which you want to remove the SnapMirror policy rules. IP addresses are not supported. |
true |
true (ByValue, ByPropertyName) |
SourceStorageSystemVolume |
Specifies the source volume of the SnapMirror relationship for which you want to remove the SnapMirror policy rules. |
true |
true (ByPropertyName) |
DestinationStorageSystem |
Specifies the secondary storage system name containing the destination volumes of the SnapMirror relationship for which you want to remove the SnapMirror policy rules. IP addresses are not supported. |
true |
DestinationStorageSystemVolume |
Specifies the destination volume of the SnapMirror relationship for which you want to remove the SnapMirror policy rules. |
true |
SnapMirrorLabel |
Specifies the SnapMirror policy rule which you want to remove. |
true |
Session |
false |
Host |
Specifies the name or IP address of the host on which you execute the operation. The default is your local machine. |
false |
Example 1: Removing SnapMirror policy rule information from the policy for a SnapMirror relationship
PS C:\> Remove-SdSnapMirrorPolicyRule -SourceStorageSystem vs01 -SourceStorageSystemVolume src_vol01 -DestinationStorageSystem vs02 -DestinationStorageSystemVolume dest_vol01 -SnapMirrorLabel myWeekly,myMonthly -verbose -Confirm:$false
Removes the SnapMirror policy rules (myWeekly, myMonthly) from the policy on the specified relationship.
