Send-SmDataCollectionEms
Starts the EMS data collection process. This is primarily an internal cmdlet and generally should not be used by customers.
Syntax
Detailed Description
Starts the EMS data collection process. EMS data collection messages are sent by default on a weekly basis. You can use the Set-SmDataCollectionEmsSchedule cmdletto change the default schedule. This is primarily an internal cmdlet and generally should not be used by customers.
| Name | Description | Required? | Pipeline Input | Default Value |
