SnapCenter cmdlets
Add-SdIgroupInitiator
Adds one or more FCP and/or iSCSI initiators to an existing igroup on your storage system.
Syntax
Add-SdIgroupInitiator [-Name]  <String>  [-Initiators]  <String[]>  [-StorageSystem]  <String>  [-Validate]  <>  [-Session]  <String>  [-Host]  <String>
Detailed Description
Adds one or more FCP and/or iSCSI initiators to an existing igroup on your storage system. You should not mix FCP and iSCSI initiators on a specified Windows node. You can mix FCP and iSCSI initiators in a clustered scenario on a Windows node.
Name Description Required? Pipeline Input Default Value
Name
Specifies the name of the igroup to which you want to add an array of FCP or iSCSI initiators.
true
true (ByPropertyName)
Initiators
Provides a comma-separated list of the FCP or iSCSI initiators you want to add to your igroup.
true
StorageSystem
Specifies the storage system on which your igroup is defined.
true
Validate
false
Session
Specifies the session ID from Open-SmConnection
false
Host
Specifies the name or IP address of the host on which you execute the operation. The default is your local machine.
false
Example 1: Adding an FCP initiator to an igroup
 PS C:\> Add-SdIgroupInitiator -Name IGroupFCPDemo -Initiators "20:00:00:0e:13:75:90:02" -StorageSystem 172.17.168.13
This example syntax adds an FCP initiator to the specified igroup.
Example 2: Adding an iSCSI initiator to an igroup
 PS C:\> Add-SdIgroupInitiator -Name IgroupDemo -Initiators iqn.1991-05.com.microsoft:mva-s24-rx200.sddev.mycompany.com -StorageSystem 172.17.168.13
This example syntax adds an iSCSI initiator to the specified igroup.
Example 3: Adding an array of initiators to your igroup
 PS C:\> Add-SdIgroupInitiator -Name IgroupDemo -Initiators iqn.1991-05.com.microsoft:mva-s24-rx200.sddev.mycompany.com,iqn.1991-05.com.microsoft:mva-rx200-s4.sddev.mycompany.com -StorageSystem 172.17.168.13
This example syntax adds an array of initiators to the specified igroup.
