SnapCenter cmdlets
Add-SmProtectResource
Protects a resource so that it is available for backup, restore and clone.
Syntax
Add-SmProtectResource [-ArchivedLocators]  <Hashtable[]>  [-PluginCode]  <PluginCode>  [-EnableEmail]  <>  [-EmailPreference]  <SmEmailNotificationPreference>
Detailed Description
Name Description Required? Pipeline Input Default Value
ArchivedLocators
Specifies in a hashtable the secondary storage system details for each unique primary storage system resource in the resource group. For example:-ArchivedLocators @{Primary="my_vs1:my_vol_iscsi";Secondary="my_vs1:my_vol_iscsi_SECONDARY"}
false
true (ByPropertyName)
PluginCode
Specifies the plug-in code of the host for which you are creating a backup resource group. Valid values are SCSQL, SCW, and SCO.
true
EnableEmail
Specifies whether to enable or disable email.
false
false
EmailPreference
Specifies when you will receive e-mail notifications.Possible values: Always, Never, OnError, OnErrorOrWarning.
false
false
Resources
Specifies the resource you want to protect. You mustprovide the resource information in a key value format, and itmustcontain the resource name, type, and the host on which it islocated.For example, -Resources@{"Host"="host.example.com";"Type"="SQL Database";"Names"="NB-MVA-DEV054\newdb"} For Oracle Database, the format is -Resources @{"Host"="host.example.com";"Oracle Database"="db"}. For Oracle Application Volume, the format is -Resources @{"Host"="host.example.com";"Application Volume"="appVol"}.
true
Provides an optional description of the resource to beprotected.
false
Tag
Enables you to apply a unique tag to help identify the resources. For example, you can add the tag "HR" to multiple resource groups. You can later search for all resource groups with the "HR" tag.
false
Policies
Specifies the list of policies associated with the resource group. Multiple policies can be added as a comma-separated list.
false
SchedulerCredentialName
false
SchedulerInstance
Specifies the SQL Server Instance where the schedule is created and managed. This is mandatory if the policy has SQL scheduler enabled.
false
VerificationServers
Specifies the list of verification servers to be associated with the resource group. Multiple verification servers can be added as a comma-separated list. This parameter is only required when you want to verify backups for SnapCenter Plug-in for Microsoft SQL Server resource groups.
false
CustomSnapshotFormat
Specifies that you want to use a custom Snapshot copy naming format. By default, a timestamp is appended to the Snapshot copy name. Valid values for CustomSnapshotFormat are : $ResourceGroup, $Policy, $HostName, $ScheduleType, $CustomText
false
CustomText
Specifies the custom text in the custom Snapshot copy naming format.
false
DeleteBackupForDetachPolicies
false
Schedules
Specifies the schedule parameters to be used in the resource group. Schedule parameters can include the policy name, schedule type, schedule start and end times. You can specify multiple schedules in a comma-separated list, for example:-Schedules @{"PolicyName"="BackupPolicy";"ScheduleType"="OneTime"}, @{"PolicyName"="BackupPolicy";"ScheduleType"="Hourly";"StartTime"=" 05/27/2016 6:13 PM";"EndTime"="'05/27/2016 6:30 PM'"}
false
SchedulerType
Specifies the scheduler type. Possible values are Windows, SQL, None.
false
VerificationSchedules
Specifies the verification schedules you want to add to the resource. The verification schedule includes the following parameters:"VerificationType" which defines if and when verification is performed. The following values are available:VERIFY_SCHEDULEDVERIFY_AFTER_BACKUPNONE"ScheduleType" represents the schedule type for the verification."BackupScheduleType" represents the schedule type for the backup-VerificationServers "WIN-DVGQDI73QR6" needs to be provided in the above command if we are creating verification enabled resource group for SCSQL plugin.
false
BackupArchiveLogsAfterRecentMissingOne
This option is only valid for SCO plugin code. Specifies that you want to backup archive log files, which are created after the most recent missing archive log files and ignore the files created prior to it. If this option is not specified, then all archive log files except the missing archive log files are be backed up.
false
ExcludeArchiveLogPathsFromBackup
This option is only valid for SCO plugin code. Specifies the archive log destinations to be excluded from backup. Archive log files present in the specified destinations will be excluded during log backup. Multiple entries can be specified using comma separated list. For example: -ExcludeArchiveLogPathsFromBackup '/arch/logs/on/local/disk1, /arch/logs/on/local/disk2'.
false
ConsistencyGroupSnapshot
false
ConsistencyGroupWaflSync
false
ConsistencyGroupTimeOut
false
SnapShotCreateCommand
false
UseFileSystemConsistentSnapshot
false
UseSnapcenterWithoutFileSystemConsistency
false
PreAppQuiesceCmd
false
PostAppQuiesceCmd
false
AppQuiesceCmd
false
AppUnQuiesceCmd
false
PreAppUnQuiesceCmd
false
PostAppUnQuiesceCmd
false
PreExitCmd
false
PreSnapshotCmd
false
PostSnapshotCmd
false
AppIgnoreError
false
UseExternalSnapShot
false
ExternalSnapshotRegex
false
ConfigParams
false
Example 1: Protecting a resource
 Add-SmProtectResource -PluginCode SCSQL  -Policies BackupPolicy -Resources @{"Host"="host.example.com";"Type"="SQL Database";"Names"="NB-MVA-DEV054\newdb"} -Description test -EnableAsupOnFailure -Schedules @{"PolicyName"="p2";"ScheduleType"="Monthly";"daysOfTheMonth"="31";"monthsOfTheYear"="August,September";} -SchedulerRunAsName Administrator -SchedulerType Windows
This example syntax protects a resource.
Example 2: Protecting a resource with hourly backup policy
          -Resources @{"Host"="host.example.com";"Type"="SQL Database";"Names"="NBMVA-DEV054\newdb"} -Description test -EnableAsupOnFailure -schedules @{"PolicyName"="BackupPolicy";"StartTime"="05/21/2019 7:54 PM";"EndTime"="05/21/2019 8:03 PM";"ScheduleType"="Hourly";"RepeatTask_Every_Hour"="03:00"} -SchedulerType Windows
Example 3: Protecting a resource with daily backup policy
          -Resources @{"Host"="host.example.com";"Type"="SQL Database";"Names"="NBMVA-DEV054\newdb"} -Description test -EnableAsupOnFailure -schedules @{"PolicyName"="BackupPolicy";"StartTime"="05/21/2019 8:09 PM";"EndTime"="05/21/2019 9:18 PM";"ScheduleType"="Daily";"daysInterval"="1"} -SchedulerType Windows
Example 4: Protecting a resource with weekly backup policy
          -Resources @{"Host"="host.example.com";"Type"="SQL Database";"Names"="NBMVA-DEV054\newdb"} -Description test -EnableAsupOnFailure -schedules @{"PolicyName"="BackupPolicy";"StartTime"="05/21/2019 8:24 PM";"EndTime"="05/21/2019 8:41 PM";"ScheduleType"="Weekly";"DaysOfTheWeek"="Tuesday"} -SchedulerType Windows
Example 5: Protecting a resource with monthly backup policy
          -Resources @{"Host"="host.example.com";"Type"="SQL Database";"Names"="NBMVA-DEV054\newdb"} -Description test -EnableAsupOnFailure -schedules @{"PolicyName"="BackupPolicy";"StartTime"="05/21/2019 8:51 PM";"EndTime"="05/21/2019 9:18 PM";"ScheduleType"="Monthly";"MonthsOfTheYear"="May,June";"daysOfTheMonth"="21,26,16"} -SchedulerType Windows
Example 6: Protecting a HANA resource
 Add-SmProtectResource -PluginCode HANA -Resources @{"Host"="schana02.gdl.englab.netapp.com";"Uid"="MDC\R57"} -Policies "HANAPOLICY"
This example protects a resource.
Tag :
ByPassRunAs : False
Configuration   : SMCoreContracts.SmConfiguration
CreationTime: 02-Oct-19 21:47:16
CustomSnapshotFormat:
CustomText  :
Description :
EmailBody   :
EmailFrom   :
EmailNotificationPreference :
EmailSMTPServer :
EmailSubject:
EmailTo :
EnableAsupOnFailure :
EnableEmail :
EnableSysLog:
HostResourceMaping  : {}
IsCustomSnapshot:
LastBackupStatus:
MaintenanceStatus   : Production
ModificationTime: 02-Oct-19 21:47:16
PluginProtectionGroupTypes  : {hana}
Policies: {}
ProtectionGroupType : Backup
SchedulerSQLInstance:
SearchResources : False
VerificationServer  :
VerificationServerInfo  : SMCoreContracts.SmVerificationServerInfo
Type: Group
Host:
UserName:
Passphrase  :
Deleted : False
Auth: SMCoreContracts.SmAuth
IsClone : False
CloneLevel  : 0
Hosts   : {}
StorageName :
ResourceGroupNames  :
PolicyNames :
Key : 0
NsmObjectID : 0
Example 7: Protecting an Oracle Application Volume resource
 Add-SmProtectResource -PluginCode SCO -Resources @{"Host"="R8092776CF4V1.HNK2.com";"Application Volume"="appVol"} -Policies "appVolPolicy"
This example protects an Oracle application volume resource named appVol.
Description :
			CreationTime: 11/4/2021 4:41:46 AM
			ModificationTime: 11/4/2021 4:41:46 AM
			EnableEmail :
			EmailSMTPServer :
			EmailFrom   :
			EmailTo :
			EmailSubject:
			EnableSysLog:
			Policies: {}
			LastBackupStatus:
			EmailBody   :
			CustomText  :
			ByPassRunAs : False
			IsCustomSnapshot:
			PluginProtectionGroupTypes  : {SCO}
			Tag :
			IsInternal  : True
			EnableEmailAttachment   :
			VerificationSettings: {}
			BackupServers   : {}
			EnableRecentSnapshotNaming  :
			Type: Group
			Host:
			UserName:
			Passphrase  :
			Deleted : False
			IsClone : False
			CloneLevel  : 0
			Hosts   : {}
			StorageName :
			PolicyNames :
			Key : 0
			NsmObjectID : 0
			SizeOfSmObject  : SMCoreContracts.SmObjectSize
Example 8: Protecting an Oracle Database resource
 Add-SmProtectResource -PluginCode SCO -Resources @{"Host"="R8092776CF4V1.HNK2.com";"Oracle Database"="DB16"} -Policies "dbPolicy"
This example protects an Oracle database resource named DB16.
Description :
			CreationTime: 11/4/2021 5:05:51 AM
			ModificationTime: 11/4/2021 5:05:51 AM
			EnableEmail :
			EmailSMTPServer :
			EmailFrom   :
			EmailTo :
			EmailSubject:
			EnableSysLog:
			Policies: {}
			LastBackupStatus:
			EmailBody   :
			CustomText  :
			ByPassRunAs : False
			IsCustomSnapshot:
			Tag :
			IsInternal  : True
			BackupServers   : {}
			Type: Group
			Host:
			UserName:
			Passphrase  :
			Deleted : False
			IsClone : False
			CloneLevel  : 0
			Hosts   : {}
			StorageName :
			PolicyNames :
			Key : 0
			NsmObjectID : 0
