Configure-SmDatabase
Configures database in SnapCenter.
Syntax
Configure-SmDatabase [-PluginCode] <PluginCode> [-ResourceId] <String> [-HDBSQLOSUser] <String> [-HDBUserStoreKey] <String> [-PluginCode] <PluginCode> [-ResourceId] <String> [-CredentialName] <String>
Detailed Description
Configure database settings in SnapCenter.
| Name | Description | Required? | Pipeline Input | Default Value |
Example: Configuring HANA resource
Configure-SmDatabase -PluginCode HANA -ResourceId "test" -HDBSQLOSUser "test" -HDBUserStoreKey "test"
This example shows how to configure database credentials for HANA Database.
Successfully updated the database configuration details.
Example: Configuring MYSQL resource
Configure-SmDatabase -PluginCode MYSQL -ResourceId "lvm-rhel65-71.netapp.com\MySQL\mysqld_3306" -CredentialName "mysql_cred"
This example shows how to configure database credentials for MYSQL Database when passing existing credential.
Successfully updated the cluster/instance configuration details.
Example: Configuring POSTGRESQL resource
Configure-SmDatabase -PluginCode POSTGRESQL -ResourceId "scs000351114.netapp.com\PostgreSQL\postgres_5432" -CredentialName "postgres_cred"
This example shows how to configure database credentials for POSTGRESQL Database when passing existing credential.
