SnapCenter cmdlets
Get-SdStorage
Gets storage system information for Windows disks or SMB shares.
Syntax
Get-SdStorage [-StorageSystem]  <String[]>  [-ComputerName]  <String>  [-ExcludeStorageFootprint]  <>  [-ExcludeSMB]  <>  [-ExcludeSAN]  <>  [-GetMirrorInfo]  <>  [-GetUnmanagedDisks]  <>  [-CloneLevel]  <>  [-Session]  <String>  [-Host]  <String>  [-Path]  <Object[]>  [-ComputerName]  <String>  [-ExcludeStorageFootprint]  <>  [-ExcludeSMB]  <>  [-ExcludeSAN]  <>  [-GetUnmanagedDisks]  <>  [-CloneLevel]  <>  [-Session]  <String>  [-Host]  <String>
Detailed Description
Gets storage system information for Windows disks or SMB shares.You must enable the CSV feature in Windows Server 2008 R2 SP1 if you want to use that feature.
Name Description Required? Pipeline Input Default Value
StorageSystem
Specifies the storage system name or IP address from which you want to get active storage, such as SMB shares. When you use this parameter with ExcludeSMB, this parameter is ignored.
false
true (ByPropertyName)
ComputerName
Indicates the name of the host from which you want all the LUNs to be returned.
false
Restricts the storage system path results to the host resource attributes only, and excludes the storage footprint. This parameter is ignored when you specify it with Path.
false
ExcludeSMB
Indicates that you do not want to view information about SMB shares.
false
ExcludeSAN
Indicates that you do not want to view information about LUNs.
false
GetMirrorInfo
Indicates that you want to view volume relationship and state information for the volumes on the source storage resources to which you have provided a path.
false
GetUnmanagedDisks
Indicates that you want to view information about available unmanaged disks. If a disk is mapped to a LUN on an unregistered storage system, it displays as an unmanaged disk, whether it is or not.If you set the parameter ExcludeSAN, GetUnmanagedDisks is ignored.
false
CloneLevel
If the storage system information is for a clone, specifies the clone level.
false
Session
Specifies the session ID from Open-SmConnection.
false
Host
Specifies the name or IP address of the host on which you execute the operation. The default is your local machine.
false
Path
Specifies a list of Windows volumes or SMB share.You cannot mix Windows volumes with SMB shares in the same input path.
false
Example 1: Getting the storage system for a SMB share
 PS C:\> Get-SdStorage -Path "\\SQLCifsServer\SalesDBShare"
This example syntax gets the storage system path for the SMB share \\SQLCifsServer\SalesDBShare.
Example 2: Getting storage system paths for multiple SMB shares
 PS C:\> Get-SdStorage -Path "\\SQLCifsServer\SalesDBShare","\\SQLCifsServer2\MarketDBShare"
This example syntax gets the storage system path for the SMB Shares \\SQLCifsServer\SalesDBShare and \\SQLCifsServer2\MarketDBShare.
Example 3: Getting detailed information about host and storage system resources
 PS C:\> Get-SdStorage -Path \\SQLCIFSServer\SalesDBShare | %{$_.HostResource,$_.StorageSystemResource}
This example syntax gets extended information about the host resource and the storage system resource.
Example 4: Getting all the SMB shares on the specified storage systems
 PS C:\> Get-SdStorage -StorageSystem "10.225.13.110","172.17.175.75" -ExcludeSAN
This example syntax gets all the SMB shares on storage systems 10.225.13.110 and 172.17.175.75.
Example 5: Getting all Windows disks and SMB shares from registered storage systems
This example syntax gets all the Windows disks and SMB shares from all registered storage systems.
Example 6: Getting the Windows disks and SMB shares with the host resources details only on the specified storage system
 PS C:\> Get-SdStorage -StorageSystem 10.225.13.110 -ExcludeStorageFootprint
This example syntax gets information about the host resources for Windows disks and SMB shares on storage system 10.225.13.110. You can use this parameter to help your application achieve better performance if you need information about Windows disks and SMB shares but not their storage footprint.
Example 7: Getting the all the LUNs but not SMB shares
 PS C:\> Get-SdStorage -ExcludeSMB
This example syntax retrieves information about all the LUNs on the local host.
Example 8: Getting volume mirror information
 PS C:\> (Get-SdStorage -StorageSystem 172.17.165.31 -GetMirrorInfo).StorageSystemResource.Volume
This example syntax uses the -GetMirrorInfo parameter to get volume state and relationship information from the source storage system resource.
