SnapCenter cmdlets
Get-SmBackupsForPointInTimeRecovery
Get all the backups required to be mounted or cataloged for point in time recovery operation.
Syntax
Get-SmBackupsForPointInTimeRecovery [-AppObjectId]  <appObject Id>  [-PluginCode]  <plugincode>  [-BackupId]  <String>  [-BackupName]  <String>  [-OracleUntilScn]  <Int64>  [-OracleUntilTime]  <'yyyy-MM-dd HH:mi:ss'>  [-Archive]  <Hashtable[]>  [-DisplayInGroups]  <>  [-OnlyBackupsForMount]  <>  [-OnlyBackupsForCatalog]  <>
Detailed Description
The backups of a tablespace, pluggable database, or tablespace in pluggable database should be cataloged and mounted to perform point in time recovery. This command lists the backups required to be mounted or cataloged based on scn or date and time.
Name Description Required? Pipeline Input Default Value
AppObjectId
Specifies the application object identifier about which you want to get information. Specify the application object identifier format as 'host\database' for Oracle standalone database or 'clustername\database' for Oracle RAC database.
true
false
PluginCode
Specifies the plugincode.
true
false
BackupId
Specifies the ID of the backup about which you want to get information.
false
false
BackupName
Specifies the name of the backup about which you want to retrieve information.
false
true (ByPropertyName)
OracleUntilScn
Specifies the SCN till which you want to get backups to recover.
false
OracleUntilTime
Specifies the date and time till which you want to get backups to recover. You must specify the date and time in the 'yyyy-MM-dd HH:mm:ss' format. For example: '2020-06-29 20:30:00'
false
Archive
Specifies the secondary (SnapVault or SnapMirror) storage location details (destination volume) for each unique primary storage (source volume).For example: -Archive @{Primary="oracle_vs1:db1_data_vol";Secondary="my_vs1:my_vol_iscsi_SECONDARY"},@{Primary="oracle_vs2:db1_log_vol";Secondary="oracle_vs2_mirror:db1_data_log_mirror"}
false
DisplayInGroups
Set this flag to get the result in groups of mounted or not mounted and cataloged or non cataloged backups.
false
OnlyBackupsForMount
Set this flag to get the result in groups of only mounted or not-mounted backups.
false
Set this flag to get the result in groups of only cataloged or non-cataloged backups.
false
Example 1: Getting backups for Point In Time Recovery Until SCN
 Get-SmBackupsForPointInTimeRecovery -AppObjectId "linux7-6.gdl.englab.netapp.com\lvm12" -BackupId 5 -PluginCode SCO -OracleUntilScn 2693464
This example syntax gets backups for Point In Time Recovery Until SCN 2693464.
BackupId : 5
BackupName   : linux7-6_gdl_englab_netapp_com_lvm12_linux7-6_08-05-2020_05.21.11.0188_0
BackupType   : Oracle Database Data Backup
MountStatus  :
CatalogingStatus : NotCataloged
Example 2: Getting backups for Point In Time Recovery Until Time
 Get-SmBackupsForPointInTimeRecovery -AppObjectId "linux7-6.gdl.englab.netapp.com\lvm12" -PluginCode SCO -BackupId 5 -OracleUntilTime "2020-08-05 05:24:40" -OnlyBackupsForCatalog
This example syntax gets backups for Point In Time Recovery Until time "2020-08-05 05:24:40"
BackupId : 5
MountStatus  :
BackupId : 7
BackupName   : linux7-6_gdl_englab_netapp_com_lvm12_linux7-6_08-05-2020_05.21.11.0188_1
BackupType   : Oracle Database Log Backup
MountStatus  :
BackupId : 9
BackupName   : linux7-6_gdl_englab_netapp_com_lvm12_linux7-6_08-05-2020_05.21.11.7922_0
MountStatus  :
BackupId : 11
BackupName   : linux7-6_gdl_englab_netapp_com_lvm12_linux7-6_08-05-2020_05.21.11.7922_1
MountStatus  :
Example 3: Getting backups for PITR using secondary locators and Until SCN
 Get-SmBackupsForPointInTimeRecovery -PluginCode SCO -AppObjectId "linux7-6.gdl.englab.netapp.com\lvm12" -BackupId 5 -Archive @{Primary="svm1-scc2554-263-264:R706221F756V1_NFS_DB_DB1_DATA";Secondary="hnkn_sec:R706221F756V1_NFS_DB_DB1_DATA_1_dst"},@{Primary="svm1-scc2554-263-264:R706221F756V1_NFS_DB_DB1_REDO";Secondary="hnkn_sec:R706221F756V1_NFS_DB_DB1_REDO_dst"},@{Primary="svm1-scc2554-263-264:R706221F756V1_NFS_DB_DB1_LOG";Secondary="hnkn_sec:R706221F756V1_NFS_DB_DB1_LOG_1_dst"} -OracleUntilScn 2188355
This example syntax gets backups for Point In Time Recovery using secondary locators and Until SCN 2693464.
BackupId : 5
MountStatus  :
