Get-SmDownloads
Gets a supportability metrics between SnapCener Server version and plug-in version.
Syntax
Get-SmDownloads
Detailed Description
Gets and displays the details of plug-in versions supported by SnapCenter Servers.
| Name | Description | Required? | Pipeline Input | Default Value |
- Example: Get the details of all the plug-in versions supported by different SnapCenter Server versions. -
Get-SmDownloads
This example syntax retrieves the supportability metrics between the SnapCener Server version and the plug-in version.
Compatibility file version: 4.4
SMS_Name: SnapCenter Server 2.0
Version : 2.0.0.2953
SMS_GUID: 166EB1F4-0BD6-434E-B2D3-85F64FF9969B
Family_GUID : 52B25C41-C093-4B94-87AA-CC3004A4482D
NOW_Path: http://mysupport.netapp.com/NOW/cgi-bin/software/
Hash: 123123123123123123
Comments: Supports Windows Server 2012 R2
Downloaded : False
Repository_Path :
SupportedPluginPackages : {, , , ...}
IsCurrent : False
ReleaseVersion : 2.0
Name:
Type:
Id :
Host:
UserName:
Passphrase :
Deleted : False
Auth: SMCoreContracts.SmAuth
IsClone : False
CloneLevel : 0
Hosts : {}
StorageName :
ResourceGroupNames :
PolicyNames :
Key : 0
NsmObjectID : 0
SizeOfSmObject : SMCoreContracts.SmObjectSize
SMS_Name: SnapCenter Server 2.0 P1
Version : 2.0.1.21
SMS_GUID: 8DBF2456-EB7E-4E26-A324-0AF8864208D3
Downloaded : False
Repository_Path :
IsCurrent : False
ReleaseVersion : 2.0.1
Name:
Type:
Id :
Host:
UserName:
Passphrase :
Deleted : False
IsClone : False
CloneLevel : 0
Hosts : {}
StorageName :
PolicyNames :
Key : 0
NsmObjectID : 0
SMS_Name: SnapCenter Server 2.0 P2
Version : 2.0.1.26
SMS_GUID: AE5A8605-C9C5-4162-8663-E8D9993AB32A
Downloaded : False
Repository_Path :
IsCurrent : False
Name:
Type:
Id :
Host:
UserName:
Passphrase :
Deleted : False
IsClone : False
CloneLevel : 0
Hosts : {}
StorageName :
PolicyNames :
Key : 0
NsmObjectID : 0
Note: This is just snippet of the output.
