Get-SmRoleAssignedPermission
Retrieves information about permissions assigned to a designated role.
Syntax
Get-SmRoleAssignedPermission [-RoleName] <String>
Detailed Description
Retrieves information about permissions assigned to a specified role. The information includes the permission name and its attributes. The attributes are Allow, Create, Read, Update, and Delete.
Name | Description | Required? | Pipeline Input | Default Value |
RoleName |
Specifies the name of the role for which you want permission and permission attribute information. |
true |
true (ByPropertyName) |
Example 1: Getting permissions assigned to a role
Get-SmRoleAssignedPermission -RoleName SnapCenterAdmin
This example syntax gets the permissions assigned to the specified role.
AttribCode : create Name : DataSet Type : Id : 1 Host : UserName : Passphrase : Deleted: False Auth : SMCoreContracts.SmAuth IsClone: False CloneLevel : 0 AttribCode : delete Name : DataSet Type : Id : 2 Host : UserName : Passphrase : Deleted: False Auth : SMCoreContracts.SmAuth IsClone: False CloneLevel : 0 AttribCode : read Name : DataSet Type : Id : 3 Host : UserName : Passphrase : Deleted: False Auth : SMCoreContracts.SmAuth IsClone: False CloneLevel : 0 AttribCode : update Name : DataSet Type : Id : 4 Host : UserName : Passphrase : Deleted: False Auth : SMCoreContracts.SmAuth IsClone: False CloneLevel : 0 AttribCode : create Name : Policy Type : Id : 5 Host : UserName : Passphrase : Deleted: False Auth : SMCoreContracts.SmAuth IsClone: False CloneLevel : 0 AttribCode : delete Name : Policy Type : Id : 6 Host : UserName : Passphrase : Deleted: False Auth : SMCoreContracts.SmAuth IsClone: False CloneLevel : 0 AttribCode : update Name : Policy Type : Id : 7 Host : UserName : Passphrase : Deleted: False Auth : SMCoreContracts.SmAuth IsClone: False CloneLevel : 0 AttribCode : read Name : Policy Type : Id : 8 Host : UserName : Passphrase : Deleted: False Auth : SMCoreContracts.SmAuth IsClone: False CloneLevel : 0 AttribCode : create Name : Backup Type : Id : 9 Host : UserName : Passphrase : Deleted: False Auth : SMCoreContracts.SmAuth IsClone: False CloneLevel : 0 AttribCode : read Name : Backup Type : Id : 10 Host : UserName : Passphrase : Deleted: False Auth : SMCoreContracts.SmAuth IsClone: False CloneLevel : 0 AttribCode : delete Name : Backup Type : Id : 11 Host : UserName : Passphrase : Deleted: False Auth : SMCoreContracts.SmAuth IsClone: False CloneLevel : 0 AttribCode : create Name : Host Type : Id : 13 Host : UserName : Passphrase : Deleted: False Auth : SMCoreContracts.SmAuth IsClone: False CloneLevel : 0 AttribCode : delete Name : Host Type : Id : 14 Host : UserName : Passphrase : Deleted: False Auth : SMCoreContracts.SmAuth IsClone: False CloneLevel : 0 AttribCode : read Name : Host Type : Id : 15 Host : UserName : Passphrase : Deleted: False Auth : SMCoreContracts.SmAuth IsClone: False CloneLevel : 0 AttribCode : update Name : Host Type : Id : 16 Host : UserName : Passphrase : Deleted: False Auth : SMCoreContracts.SmAuth IsClone: False CloneLevel : 0 AttribCode : create Name : StorageConnection Type : Id : 17 Host : UserName : Passphrase : Deleted: False Auth : SMCoreContracts.SmAuth IsClone: False CloneLevel : 0 AttribCode : delete Name : StorageConnection Type : Id : 18 Host : UserName : Passphrase : Deleted: False Auth : SMCoreContracts.SmAuth IsClone: False CloneLevel : 0 AttribCode : read Name : StorageConnection Type : Id : 19 Host : UserName : Passphrase : Deleted: False Auth : SMCoreContracts.SmAuth IsClone: False CloneLevel : 0 AttribCode : update Name : StorageConnection Type : Id : 20 Host : UserName : Passphrase : Deleted: False Auth : SMCoreContracts.SmAuth IsClone: False CloneLevel : 0 AttribCode : create Name : Clone Type : Id : 21 Host : UserName : Passphrase : Deleted: False Auth : SMCoreContracts.SmAuth IsClone: False CloneLevel : 0 AttribCode : delete Name : Clone Type : Id : 22 Host : UserName : Passphrase : Deleted: False Auth : SMCoreContracts.SmAuth IsClone: False CloneLevel : 0 AttribCode : read Name : Clone Type : Id : 23 Host : UserName : Passphrase : Deleted: False Auth : SMCoreContracts.SmAuth IsClone: False CloneLevel : 0 AttribCode : update Name : Clone Type : Id : 24 Host : UserName : Passphrase : Deleted: False Auth : SMCoreContracts.SmAuth IsClone: False CloneLevel : 0 AttribCode : create Name : Provision Type : Id : 25 Host : UserName : Passphrase : Deleted: False Auth : SMCoreContracts.SmAuth IsClone: False CloneLevel : 0 AttribCode : delete Name : Provision Type : Id : 26 Host : UserName : Passphrase : Deleted: False Auth : SMCoreContracts.SmAuth IsClone: False CloneLevel : 0 AttribCode : read Name : Provision Type : Id : 27 Host : UserName : Passphrase : Deleted: False Auth : SMCoreContracts.SmAuth IsClone: False CloneLevel : 0 AttribCode : update Name : Provision Type : Id : 28 Host : UserName : Passphrase : Deleted: False Auth : SMCoreContracts.SmAuth IsClone: False CloneLevel : 0 AttribCode : update Name : Backup Type : Id : 45 Host : UserName : Passphrase : Deleted: False Auth : SMCoreContracts.SmAuth IsClone: False CloneLevel : 0 AttribCode : allow Name : DashBoard Type : Id : 51 Host : UserName : Passphrase : Deleted: False Auth : SMCoreContracts.SmAuth IsClone: False CloneLevel : 0 AttribCode : allow Name : Reports Type : Id : 52 Host : UserName : Passphrase : Deleted: False Auth : SMCoreContracts.SmAuth IsClone: False CloneLevel : 0 AttribCode : allow Name : Restore Type : Id : 53 Host : UserName : Passphrase : Deleted: False Auth : SMCoreContracts.SmAuth IsClone: False CloneLevel : 0 AttribCode : allow Name : Discovery Type : Id : 54 Host : UserName : Passphrase : Deleted: False Auth : SMCoreContracts.SmAuth IsClone: False CloneLevel : 0 AttribCode : allow Name : Plugin_Installation Type : Id : 58 Host : UserName : Passphrase : Deleted: False Auth : SMCoreContracts.SmAuth IsClone: False CloneLevel : 0 AttribCode : allow Name : Migration Type : Id : 59 Host : UserName : Passphrase : Deleted: False Auth : SMCoreContracts.SmAuth IsClone: False CloneLevel : 0
