SnapCenter cmdlets
Get-SmRolePermissions
Retrieves permissions and associated permission attribute codes available in SnapCenter.
Syntax
Get-SmRolePermissions [-Name]  <String>
Detailed Description
Retrieves permissions and associated permission attribute codes available in SnapCenter. If you specify a permission name, you receive attribute codes associated with that permission. If you do not specify a name, you retrieve all permissions available in SnapCenter.
Name Description Required? Pipeline Input Default Value
Name
Specifies the name of the Run As account that you want to get information about.
false
true (ByPropertyName)
Example 1: Getting information about a specified permission
 Get-SmRolePermissions -Name DataSet
This example syntax lists the information for the specified permission.
PermissionName PermissionCode
DataSet create
DataSet delete
DataSet read
DataSet update
Example 2: Getting a list of permissions available in SnapCenter
This example syntax displays permissions for all permissions in SnapCenter.
DataSet create
DataSet delete
DataSet read
DataSet update
Policy create
Policy delete
Policy update
Policy read
Backup create
Backup read
Backup delete
Host create
Host delete
Host read
Host update
StorageConnection create
StorageConnection delete
StorageConnection read
StorageConnection update
Clone create
Clone delete
Clone read
Clone update
Provision create
Provision delete
Provision read
Provision update
Backup update
DashBoard allow
Reports allow
Restore allow
Discovery allow
Plugin_Installation allow
Migration allow
