Invoke-SdSnapMirrorUpdate
Facilitates updates to mirror and vault relationships, in the context of Windows disks, SMB shares, or clustered Data ONTAP storage system volumes.
Syntax
Invoke-SdSnapMirrorUpdate [-Path] <Object> [-MaxTransferRate] <Int64> [-Snapshot] <String> [-Session] <String> [-Host] <String> [-SourceStorageSystem] <String> [-SourceVolumeName] <String> [-DestinationStorageSystemName] <String> [-DestinationStorageVolumeName] <String> [-MaxTransferRate] <Int64> [-Snapshot] <String> [-Session] <String> [-Host] <String>
Detailed Description
Facilitates updates to mirror and vault relationships, in the context of Windows disks, SMB shares, or clustered Data ONTAP storage system volumes. For the specified resources, you can determinethe underlying storage layout and issue SnapMirror updates on the corresponding storage volumes, provided that the SnapMirror relationship is already created and initialized. SnapMirror updates and returns are executed immediately.When you are updating a SnapMirror relationship, you can specify a share, storage system volume, or Windows disk. When you are updating a SnapVault relationship, you can specify a share or storage system volume. Related cmdlets: Restore-SdSnapshot and New-SdSnapshot
| Name | Description | Required? | Pipeline Input | Default Value |
| Path | Provides a volume, logical disk, SMB share for which you want SnapMirror updates.You cannot mix a logical disk or mount point with SMB shares in the same input path.When you are updating a SnapMirror relationship, you can specify a share, storage system volume, or Windows disk. When you are updating a SnapVault relationship, you can specify a share or storage system volume. | true | true (ByValue, ByPropertyName) | |
| MaxTransferRate | Specifies the maximum transfer rate, in bytes per second. | false | true (ByPropertyName) | |
| Snapshot | Specifies the Snapshot copy you want to transfer. This cmdlet is processed only for vault relationships; in the case of SnapMirror relationships, this parameter is ignored if specified. | false | true (ByPropertyName) | |
| Session | false | true (ByPropertyName) | ||
| Host | Specifies the name or IP address of the host on which you execute the operation. The default is your local machine. | false | true (ByPropertyName) | localmachine |
| SourceStorageSystem | Specifies the storage system from which you want to update your SnapMirror relationships. | true | true (ByPropertyName) | |
| SourceVolumeName | Specifies the volume from which you want to update your SnapMirror relationships. | true | true (ByPropertyName) | |
| DestinationStorageSystemName | Specifies the storage system on which you want to update your SnapMirror relationships. Must be used in conjunction with DestinationStorageVolumeName. If you do not specify this parameter, all storage system volumes associated with your source storage system and volume are updated. | false | true (ByPropertyName) | |
| DestinationStorageVolumeName | Specifies the volume on which you want to update your SnapMirror relationships. Must be used in conjunction with DestinationStorageSystemName. If you do not specify this parameter, all storage system volumes associated with your source storage system and volume are updated. | false | true (ByPropertyName) |
Example 1: Updating SnapMirror for a single share
PS C:\> Invoke-SdSnapMirrorUpdate -path "\\fileserver\sqlshare"
In this example syntax, you determine the underlying storage footprint for \\fileserver\sqlshare, and initiate a SnapMirror update on the underlying volume, provided that the SnapMirror relationship is created and initialized.
PS C:\Users\administrator.NEXTGEN> Invoke-SdSnapMirrorUpdate -Path \\CIFS_SERV\snapvault_source -Verbose VERBOSE: Validating input paths. VERBOSE: SMB Share : \\CIFS_SERV\snapvault_source VERBOSE: Updating SnapMirror. SnapMirrorRelationshipType : SnapMirrorPolicyName : SnapMirrorRelationship : vserver : snapvault_source ==> vserver : snapvault_dest SnapMirrorState: snapmirrored SnapMirrorStatus : Transfering Lag: 0 LagSpecified : False BaseSnapshotName : local Message: VERBOSE: Operation successful.
Example 2: Updating your vault for a single share
PS C:\> Invoke-SdSnapMirrorUpdate -path "\\fileserver\sqlshare" -snapshot "weeklybackup"
In this example syntax, you determine the underlying storage footprint for \\fileserver\sqlshare, and initiate a SnapVault update on the underlying volume.
PS C:\Users\administrator.NEXTGEN> Invoke-SdSnapMirrorUpdate -Path \\CIFS_SERV\snapvault_source -Snapshot local -Verbose VERBOSE: Validating input paths. VERBOSE: SMB Share : \\CIFS_SERV\snapvault_source VERBOSE: Updating SnapMirror. SnapMirrorRelationshipType : SnapMirrorPolicyName : SnapMirrorRelationship : vserver1 : snapvault_source ==> vserver1 : snapvault_dest SnapMirrorState: snapmirrored SnapMirrorStatus : Transfering Lag: 0 LagSpecified : False BaseSnapshotName : DATA Message: VERBOSE: Operation successful.
Example 3: Updating SnapMirror for a disk
PS C:\> Invoke-SdSnapMirrorUpdate -Path E:
In this example syntax, you determine the underlying storage footprint for disk drive E:, and initiate a SnapMirror update on the underlying volume, provided that the SnapMirror relationship is created and initialized.
Example 4: Updating all SnapMirror destination storage system volumes
PS C:\> Invoke-SdSnapMirrorUpdate -SourceStorageSystem sdw_jenkins_vserver -SourceVolumeName VOLUME01 -Verbose
In this example syntax, you update all destination storage system volumes associated with the source storage system and volume.
VERBOSE: Updating Snapmirror.. SnapMirrorRelationshipType : SnapMirrorPolicyName : SnapMirrorRelationship : sdw_jenkins_vserver : VOLUME01 ==> sdw_jenkins_vserver : vserver01 SnapMirrorState: snapmirrored SnapMirrorStatus : Transfering Lag: 0 LagSpecified : False BaseSnapshotName : snapmirror.e0f01251-4d32-11dc-a3b0-123478563412_2147485514.2013-07-17_143103 Message: SnapMirrorRelationshipType : SnapMirrorPolicyName : SnapMirrorRelationship : sdw_jenkins_vserver : VOLUME01 ==> sdw_jenkins_vserver : VOLUME01_Sec SnapMirrorState: snapmirrored SnapMirrorStatus : Transfering Lag: 0 LagSpecified : False BaseSnapshotName : TEST_TEST Message: VERBOSE: Operation Successful.
Example 5: Updating specified SnapMirror destination storage system volumes
PS C:\> Invoke-SdSnapMirrorUpdate -SourceStorageSystem sdw_jenkins_vserver -SourceVolumeName VOLUME01 -DestinationStorageSystemName sdw_jenkins_vserver -DestinationStorageVolumeName VOLUME01_Sec -Verbose
In this example syntax, you update specific destination storage system volumes associated with the source storage system and volume.
VERBOSE: Updating Snapmirror.. SnapMirrorRelationshipType : SnapMirrorPolicyName : SnapMirrorRelationship : sdw_jenkins_vserver : VOLUME01 ==> sdw_jenkins_vserver : VOLUME01_Sec SnapMirrorState: snapmirrored SnapMirrorStatus : Transfering Lag: 0 LagSpecified : False BaseSnapshotName : TEST_TEST Message: VERBOSE: Operation Successful.
 PDFs
PDFs
