SnapCenter cmdlets
Invoke-SmTechRefreshHost
Perform tech refresh of source host with destination host.
Syntax
Invoke-SmTechRefreshHost [-OldHostName]  <String>  [-NewHostName]  <String>  [-IsDryRun]  <Boolean>  [-AutoMigrateManuallyAddedResource]  <Boolean>  [-SQLInstanceMapping]  <Hashtable[]>
Detailed Description
Name Description Required? Pipeline Input Default Value
OldHostName
Specify the name of source host whose resources needs to be relinked.
true
true (ByPropertyName)
NewHostName
Specify the name of destination host where you want to relink the resources of the source host.
true
IsDryRun
Specify whether you want to perform a dry run to find the matching resources without relinking them.
false
True
Specify whether you want to migrate unmatched manually added resources.
false
False
SQLInstanceMapping
Specify the list of SQL instance mapping, if resource is being migrated to another instance on new host.You must provide the instance mapping in a hashtable, and it must contain the OldInstanceName and NewInstanceName. For example,@{"OldInstanceName"="instance1";"NewInstanceName"="instance1_new"},@{"OldInstanceName"="instance2";"NewInstanceName"="instance2_new"} You can include comma-separated values for multiple instance mapping.
false
Example 1: Tech refresh of old host with new host.
 Invoke-SmTechRefreshHost -OldHostName host.mva.gdl.netapp.com -NewHostName hostNew.mva.gdl.netapp.com -IsDryRun 0 -AutoMigrateManuallyAddedResource 1
Initiating host tech refresh..
Name: Tech refresh of host 'host.mva.gdl.netapp.com' with host 'hostNew.mva.gdl.netapp.com'
StartTime   : 9/11/2023 6:10:43 PM
EndTime : 9/11/2023 6:10:43 PM
IsCancellable   : False
IsRestartable   : False
IsCompleted : False
IsVisible   : True
IsScheduled : False
PercentageCompleted : 100
Description :
Status  : Running
Owner   :
Error   :
Priority: None
Tasks   : {Precheck validation}
ParentJobID : 0
EventId : 0
JobTypeId   : 10
ApisJobKey  :
ObjectId: 0
PluginCode  : NONE
PluginName  : NONE
HostId  : 0
RoleId  :
JobIds  : {}
ScsJobId:
Invoke-SmTechRefreshHost Completed
This example does a tech refresh of old host with new host
Example 2: Tech refresh of old host with new host when SQL resource is migrated from one instance to another
-SQLInstanceMapping @{"OldInstanceName"="instance1";"NewInstanceName"="instance1_new"},@{"OldInstanceName"="instance2";"NewInstanceName"="instance2_new"}
IsCompleted : False
IsVisible   : True
IsScheduled : False
Description :
Status  : Running
Owner   :
Error   :
Priority: None
ParentJobID : 0
EventId : 0
JobTypeId   : 10
ApisJobKey  :
ObjectId: 0
PluginCode  : NONE
PluginName  : NONE
HostId  : 0
RoleId  :
JobIds  : {}
ScsJobId:
