SnapCenter cmdlets
Mount-SdSnapshot
Facilitates mounting the list of SMB shares from the specified Snapshot copy as a different set of shares. Facilitates mounting one LUN at a time from the specified Snapshot copy as a different LUN.
Mounting secondary LUN is not supported, Check Example 9
Syntax
Mount-SdSnapshot [-Path]  <Object[]>  [-Snapshot]  <String>  [-StorageSystem]  <String>  [-VolumeName]  <String>  [-PrefixForVolumeClone]  <String>  [-MountPath]  <Object[]>  [-SharedDisk]  <>  [-ClusteredSharedVolume]  <>  [-AutopickMountPoint]  <>  [-ValidateCloneDepth]  <>  [-Session]  <String>  [-Host]  <String>
Detailed Description
Facilitates mounting the list of SMB shares from the specified Snapshot copy as a different set of shares. Facilitates mounting one LUN at a time from the specified Snapshot copy as a different LUN.You can use this cmdlet to perform backup verification. Mount the database and log shares/LUN from the Snapshot copy and perform the verification operations. For SMB shares, the mounted share names are automatically appended with a unique identifier. For a LUN, the cloned volume name is automatically appended with a unique identifier, while the LUN name remains the same.For example:If the original share is \\SQLFileServer\DBShare, the mounted share name is \\SQLFileServer\DBShare-GUID. (\\SQLFileServer\DBShare-73111E50-E7C2-49B7-8A63-7279512CB09B)If the original LUN is PrimarySVM:/vol/SCE_VOL/lun1, the mounted LUN name is PrimarySVM:/vol/SCE_VOLGUID/lun1. (PrimarySVM:/vol/SCE_VOLSiClone2b77c074_1d9b_4929_9fac_d361bf342794/lun1)The ACLs on the mounted share are the same as the original share. To mount the shares or a LUN from a secondary Snapshot copy, you must specify the storage system and volume.Ensure that the aggregate of the volume that is the source of the FlexClone operation is assigned to the virtual storage server aggregates list.For the 'Path' parameter below, if file system path of the LUN is specified, it can be mounted on the same host as the source LUN. If the complete storage path of the LUN is specified, it can be mounted on the same host or on a different host.To mount the LUN on a different host, an igroup and an iSCSI session should to be present for the host that is accessing the SVM, where the source LUN is present.Related cmdlets: Get-SdSnapshot, Remove-SdSnapshot, Rename-SdSnapshot, New-SdSnapshot, Dismount-SdSnapshot
Name Description Required? Pipeline Input Default Value
Path
Specifies a comma-separated list of shares you want to mount from the Snapshot copy.Only one LUN can be mounted at a time. For a LUN, this parameter specifies one value which is the file system path of the LUN in the host machine or the complete storage path of the LUN in the SVM.You cannot mix a logical disk or mount point with SMB shares in the same input path.
true
true (ByPropertyName)
Snapshot
Indicates the Snapshot copy that you want to use for mounting the SMB shares/LUN. For SMB shares, you must use a Snapshot copy that is valid for all the shares in your list.
true
StorageSystem
Indicates the name of the storage system in which the Snapshot copy you want to mount is located.
false
VolumeName
Indicates the name of the storage system volume in which the Snapshot copy you want to mount is located.
false
You can use this optional parameter to set a short name for the share on which the Snapshot copy is mounted. For LUNs, use this parameter to prefix the cloned volume name. Use this parameter when you are working on a system with name length restrictions.
false
MountPath
Indicates the drive letter or mountpoint that you want to assign to the disk mounted from the Snapshot copy. For a LUN mount operation, this parameter takes only one destination value.
false
SharedDisk
false
false
AutopickMountPoint
Specifies that the mountpoint is assigned automatically.
false
ValidateCloneDepth
false
false
Session
false
Host
Specifies the name or IP address of the host on which you execute the operation. For SMB shares, the default is your local machine. For a LUN, this parameter must be provided with the hostname.
false
Example 1: Mounting shares from a specified backup
 PS C:\> Mount-SdSnapshot -Path "\\SQLFileserver\DBShare","\\SQLFileserver\LogShare" -snapshot "weekly_backup"
This example syntax mounts your shares from "weekly_backup".
OriginalResource MountedResource
\\SQLFileserver\DBShare \\SQLFileserver\DBShare-A470FF3A-5107-4B6A-B0C1-FB3D8744F14C
\\SQLFileserver\LogShare \\SQLFileserver\DBShare-E6980DF6-3E64-45BD-965A-7F7A9B02156A
Example 2: Mounting shares from piped Snapshot copies that start with "weekly" in the name.
 PS C:\> Get-SdSnapshot \\SQLFileserver\DBShare -Snapshot weekly* | Mount-SdSnapshot  "\\SQLFileserver\dbshare","\\SQLFileserver\logshare"
This example syntax mounts specified shares from Snapshot copies that start with "weekly." The shares you want to mount must be on the same volume.
\\SQLFileserver\LogShare \\SQLFileserver \DBShareE6980DF6-3E64-45BD-965A-7F7A9B02156A
Example 3: Mounting shares from the specified secondary Snapshot copy
 PS C:\> Mount-SdSnapshot -Path "\\SQLFileserver\DBShare","\\SQLFileserver\LogShare" -snapshot "weekly_snap" -storagesystem mirror_vserver -volume dbmirrorvolume
This example mounts the specified shares from the specified secondary Snapshot copy.
\\SQLFileserver\DBShare \\DRSQLFileServer\DBShare-A470FF3A-5107-4B6A-B0C1-FB3D8744F14C
\\SQLFileserver\LogShare \\DRSQLFileServer\DBShare-E6980DF6-3E64-45BD-965A-7F7A9B02156A
Example 4: Mounting shares using a prefix
 PS C:\> Mount-SdSnapshot -Path \\172.17.165.40\capital_vol_share -Snapshot Newtest -PrefixForVolumeClone capitalShare
This example syntax creates a short name for the share on which you mount the Snapshot copy.
Resource ConnectedResource
\\172.17.165.40\capital_vol_share \\JENKINS-CIFS\capitalShare030713155542929
Example 5: Mounting a LUN from a specified Snapshot with file system path.
 PS C:\> Mount-SdSnapshot -Path L:  -Snapshot Host1_DMN_COM_SLDB3_Host1_06-10-2020_02.51.43.9645 -MountPath I: -Host Host1.DMN.COM
This example syntax mounts the Snapshot copy specified for the LUN in L: onto I: on the host Host1.DMN.COM.
L:\ I:\
Example 6: Mounting a LUN from a specified Snapshot with AutoMount option
 PS C:\> Mount-SdSnapshot -Path L:  -Snapshot Host1_DMN_COM_SLDB3_Host1_06-10-2020_02.51.43.9645 -AutopickMountPoint -Host Host1.DMN.COM
This example syntax mounts the Snapshot copy specified for the LUN in L: onto the automount location "C:\scmnpt\mpdisk0002\" on the host Host1.DMN.COM.
L:\ C:\scmnpt\mpdisk0002\
Example 7: Mounting a LUN to a different host with LUN storage path
 PS C:\> Mount-SdSnapshot -Path PrimarySVM:/vol/SCE_VOL/lun1  -Snapshot Host1_DMN_COM_SLDB3_Host1_06-10-2020_02.51.43.9645 -MountPath I: -Host Host2.DMN.COM
This example syntax specifies the storage path of the LUN mounted on Host1 and mounts the Snapshot copy onto I: on the host Host2.DMN.COM. The cmdlet is executed on Host2.DMN.COM.
L:\ I:\
Example 8: Mounting a LUN with LUN storage path using Primary SVM
 PS C:\>  Mount-SdSnapshot -Path Primary_SVM:/vol/Volume_Vault/Volume_Vault_Lun1 -Snapshot R70105EC0A5V1_SQL2019_SQL_DB1_R70105EC0A5V1_03-15-2021_22.37.23.2993_1 -PrefixForVolumeClone Clone_01292021_2330 –AutopickMountPoint -Verbose
This example syntax specifies the storage path of the Primary LUN mounted and mounts the Snapshot copy onto random drive letter on the same host using Primary Storage . The cmdlet is executed on Host1.
VERBOSE: Validating input paths.
VERBOSE: LUN: Primary_SVM:/vol/Volume_Vault/Volume_Vault_Lun1
VERBOSE: The Snapshot 'R70105EC0A5V1_SQL2019_SQL_DB1_R70105EC0A5V1_03-15-2021_22.37.23.2993_1' of Primary_SVM:/vol/Volume_Vault/Volume_Vault_Lun1 will be mounted.
VERBOSE: Drive letter if available or a mount point will be auto-picked
VERBOSE: Mounting the specified resources from the Snapshot copy.
VERBOSE: Operation successful.
Primary_SVM:/vol/Volume_Vault/Volume_Vault_Lun1   C:\scmnpt\mpdisk0006\
Example 9: Mounting a LUN with LUN storage path using Secondary Storage fails
 PS C:\>  Mount-SdSnapshot -Path Secondary_SVM:/vol/Volume_Secondary_Vault/Volume_Secondary_Vault_Lun1 -Snapshot BCHExchDAG2016_Backup_kdcbchexch1_01-29-2021_23.30.20.2845 -PrefixForVolumeClone Clone_01292021_2330 –AutopickMountPoint
This example syntax specifies the storage path of the LUN mounted and trying to mount the Snapshot copy with random drive letter on the any host using Secondary Storage . The cmdlet is executed on Host1.
Mount-SdSnapshot : Failed to mount the Snapshot copy.Failed to mount the resource: Secondary_SVM:/vol/Volume_Secondary_Vault/Volume_Secondary_Vault_Lun1 from snapshot: BCHExchDAG2016_Backup_kdcbchexch1_01-29-2021_23.30.20.2845.
The source LUN's iGroup does not exist.
Possible Resolution: Make sure that Host to storage connectivity is available.
At line:1 char:1
+ Mount-SdSnapshot -Path Secondary_SVM:/vol/Volume_Secondary_Vault/Volume_Secondary_Vault_Lun1 ...
+ CategoryInfo  : InvalidResult: (SnapDrive.Clien...MountSdSnapshot:MountSdSnapshot) [Mount-SdSnapshot], Exception
+ FullyQualifiedErrorId : 102,SnapDrive.Client.PSModule.MountSdSnapshot
