SnapCenter cmdlets
New-SdPortSet
Creates a new portset.
Syntax
New-SdPortSet [-PortSetName]  <String>  [-PortSetType]  <String>  [-StorageSystem]  <String>  [-Session]  <String>  [-Host]  <String>
Detailed Description
Name Description Required? Pipeline Input Default Value
PortSetName
Specifies the name of the portset you want to create.
true
true (ByPropertyName)
PortSetType
Specifies the protocol you want to use for your new portset. Valid options are iSCSI, Fibre Channel (FCP), or mixed.
false
StorageSystem
Specifies the storage system on which you want your new portset to reside.
true
Session
false
Host
Specifies the name or IP address of the host on which you execute the operation. The default is your local machine.
false
