SnapCenter cmdlets
New-SdSnapshot
Creates Snapshot copies of specified Windows disks or SMB shares.
Syntax
New-SdSnapshot [-Path]  <Object[]>  [-Snapshot]  <String>  [-NoCleanUpOnError]  <>  [-UpdateMirror]  <>  [-CrashConsistent]  <>  [-Session]  <String>  [-Host]  <String>
Detailed Description
Creates Snapshot copies of specified Windows disks or SMB shares.Related cmdlets: Get-SdSnapshot, Remove-SdSnapshot and Rename-SdSnapshot
Name Description Required? Pipeline Input Default Value
Path
Provides the volume, logical disk, or a comma-separated list of SMB shares of which you want to make Snapshot copies. You cannot mix a logical disk or mount point with SMB shares in the same input path.
true
true (ByValue, ByPropertyName)
Snapshot
Designates the name of the new Snapshot copy. You cannot use special characters in a Snapshot copy name. If you do not specify a Snapshot copy name, a GUID appended with timestamp is generated and used as the Snapshot copy name.
false
true (ByPropertyName)
A GUID appended with timestamp will be generated and used for the Snapshot copy name
NoCleanUpOnError
Indicates whether you want to delete Snapshot copies if there is an error in backing up one of the specified resources, that results in an incomplete Snapshot backup.
false
UpdateMirror
Initiates a mirror or vault update after your Snapshot operation completes.
false
false
CrashConsistent
false
false
Session
false
Host
Specifies the name or IP address of the host on which you execute the operation. The default is your local machine.
false
Example 1: Backing up the specified SMB shares
 PS C:\> New-SdSnapshot -Path "\\fileserver\sqlshare","\\fileserver\sqlshare2" -Snapshot "sql_snap"
This example syntax backs up the SMB shares by creating Snapshot copies of the corresponding volumes using Snapshot name sql_snap.
Example 2: Backing up the specified disk
 PS C:\> New-SdSnapshot -Path E: -Snapshot "sql_snap"
This example syntax backs up the disk drive by creating Snapshot copies of the corresponding volumes using Snapshot name sql_snap.
