SnapCenter cmdlets
New-SmBackup
Initiates a new Snapshot copy job.
Syntax
New-SmBackup [-Resources]  <Hashtable[]>  [-DatasetName]  <String>  [-ResourceGroupName]  <String>  [-Policy]  <String>  [-Auth]  <String>  [-IsScheduled]  <Boolean>  [-ClusterName]  <String>  [-SMSBaseUrl]  <String>  [-IsNLBHost]  <Boolean>  [-ScheduleName]  <String>  [-ScheduleType]  <SmSchedulerType>  [-Guid1]  <String>  [-Guid2]  <String>  [-SnapShotLabel]  <SmSPSnapShotLabel>  [-HostName]  <String>  [-VerifyOnSecondary]  <>  [-EnableVerification]  <>
Detailed Description
Initiates a new Snapshot copy job on the provided resource or the resources mapped to the provided resource group.
Name Description Required? Pipeline Input Default Value
Resources
Specifies the resource which you want to backup. For Oracle Application Volume resource, format is -Resources @{"Host"="host1";"Application Volume"="appVol1"}
false
true (ByPropertyName)
DatasetName
Names the dataset you want to back up.
false
false
ResourceGroupName
false
false
Policy
Specifies the policy you want to use for the backup operation.
true
false
Auth
This parameter is for internal use only.
false
false
IsScheduled
Internal switch to determine Cmdlet invocation by scheduler.
false
false
ClusterName
Internal switch for identifying the cluster host.
false
false
SMSBaseUrl
Internal switch that points to the SMS Base URL.
false
false
IsNLBHost
Internal switch that indicates whether this host is part of NLB.
false
false
ScheduleName
Internal switch that indicates schedule name.
false
false
ScheduleType
false
false
Guid1
false
false
Guid2
false
false
SnapShotLabel
false
false
HostName
Determines the host name (FQDN) for which the backup job has been scheduled.
false
false
VerifyOnSecondary
Specifies whether verification is enabled on secondary storage.
false
false
EnableVerification
Specifies whether verification of backups is enabled. Values are either $True or $False.
false
false
Example 1: Backing up a resource group
 New-SMBackup -ResourceGroupName FullOnlineDataset1 -Policy FullBackupPolicy
This example syntax backs up the specified resource group.
Example 2: Backing up resources
 New-SMBackup -Policy FullBackupPolicy -Resources @{"Host"="scspr0101826001-sumanr.lab.netapp.com";"Oracle Database"="ong"}
This example syntax backs up the specified resources.
Example 3: Enabling verification of a backup
 New-SMBackup -EnableVerification $true -VerifyOnSecondary $true -Policy FullBackupPolicy -Resources @{"Host"="scspr0101826001-sumanr.lab.netapp.com";"Oracle Database"="ong"}
This example syntax backs up the specified resources and verifies the backup when it completes.
Example 4: Triggering a new backup of the HANA resource
 New-SMBackup -Resources @{"Host"="schana02.gdl.englab.netapp.com";"Uid"="MDC\R57";"PluginName"="hana"} -Policy "HANAPOLICY"
This example backs up the specified resources.
Name: Backup of Resource Group 'schana02_gdl_englab_netapp_com_hana_MDC_R57' with policy 'HANAPOLICY'
StartTime   : 02-Oct-19 21:49:46
EndTime :
IsCancellable   : False
IsRestartable   : False
IsCompleted : False
IsVisible   : True
IsScheduled : False
PercentageCompleted : 0
Description :
Status  : Queued
Owner   :
Error   :
Priority: None
Tasks   : {}
ParentJobID : 0
EventId : 0
JobTypeId   : 0
ApisJobKey  :
ObjectId: 0
PluginCode  : SCC
PluginName  : PluginCreator
HostId  : 0
RoleId  :
JobIds  : {}
Example 5: Backing up an Oracle Application Volume Resource
 New-SMBackup -Policy ndvpolicy -Resources @{"Host"="R809278EA03V1.HNK2.com";"Application Volume"="appVol1"}
This example syntax backs up the specified Oracle Application Volume resource.
Example 6: Triggering a new backup of the UnixFileSystems resource
 New-SMBackup -ResourceGroupName "RG_PS_linuxfs201_LVM1_12648" -Policy "BackupPS_linuxfs201_LVM1_12648"
			Name: Backup of Resource Group 'RG_PS_linuxfs201_LVM1_12648' with policy
								  'BackupPS_linuxfs201_LVM1_12648'
			StartTime   : 12/12/2023 8:29:33 AM
			EndTime :
			IsCompleted : False
			IsVisible   : True
			IsScheduled : False
			Description :
			Status  : Queued
			Owner   :
			Error   :
			Priority: None
			Tasks   : {}
			ParentJobID : 0
			EventId : 0
			JobTypeId   : 0
			ApisJobKey  :
			ObjectId: 0
			PluginCode  : SCC
			HostId  : 0
			RoleId  :
			JobIds  : {}
			ScsJobId:
