SnapCenter cmdlets
New-SmRole
Enables you to create a role, assign users, assign groups, and assign permissions.
Syntax
New-SmRole [-Name]  <String>  [-Description]  <String>  [-Permissions]  <String>  [-AssignedUsers]  <String>  [-AssignedGroups]  <String>  [-SharedObjects]  <>
Detailed Description
Name Description Required? Pipeline Input Default Value
Name
Specifies the name of the new role.
true
true (ByPropertyName)
Specifies an optional description of the role.
false
Permissions
Specifies what permissions are assigned to the role.
false
AssignedUsers
Specifies users assigned to the role.
false
AssignedGroups
Specifies groups assigned to the role.
false
SharedObjects
false
Example 1: Creating a new role
 New-SmRole -Name TestRole
This example syntax creates a new role with the specified name.
Description :
Type:
Id  :
Host:
UserName:
Passphrase  :
Deleted : False
Auth: SMCoreContracts.SmAuth
IsClone : False
CloneLevel  : 0
Example 2: Creating a new role and assigning a user
 New-SmRole -Name TestRoleWithUser -AssignedUsers sddev\snapdrive
This example syntax creates a new role and assigns the specified user.
Description :
Type:
Id  :
Host:
UserName:
Passphrase  :
Deleted : False
IsClone : False
CloneLevel  : 0
Example 3: Creating a new role and assigning multiple users
 New-SmRole -Name TestRoleWithUsers -AssignedUsers "sddev\administrator,sddev\snapdrive"
This example syntax creates a new role and assigns multiple users to the role.
Description :
Type:
Id  :
Host:
UserName:
Passphrase  :
Deleted : False
IsClone : False
CloneLevel  : 0
Example 4: Creating a new role and assigning a group
 New-SmRole -Name TestRoleWithGroup -AssignedGroups sddev\administrators
This example syntax creates a new role and assigns the specified group to the role.
Description :
Type:
Id  :
Host:
UserName:
Passphrase  :
Deleted : False
IsClone : False
CloneLevel  : 0
Example 5: Creating a role and assigning multiple groups
 New-SmRole -Name TestRoleWithGroups -AssignedGroups "sddev\administrators, sddev\Domain Admins"
This example syntax creates a new role and assigns multiple groups to the role.
Description :
Type:
Id  :
Host:
UserName:
Passphrase  :
Deleted : False
IsClone : False
CloneLevel  : 0
Example 6: Creating a new role and assigning permissions
This example syntax creates a new role and assigns the specified permissions the groups assigned to the role.
PS C:\> New-SmRole -Name TestRoleWithPermissions -Permissions "Host: read, update, delete, crea
te;dataset: read, update, create, delete;manageusergroup: allow;Plugin_Installation: read, update"
Description :
Type:
Id  :
Host:
UserName:
Passphrase  :
Deleted : False
IsClone : False
CloneLevel  : 0
