SnapCenter cmdlets
Protect-SmRepository
Sets the configuration that is required to create a backup of the SnapCenter database.
Syntax
Protect-SmRepository [-HostName]  <String>  [-Path]  <String>  [-Schedule]  <Hashtable>  [-RetentionCount]  <Int32>
Detailed Description
Name Description Required? Pipeline Input Default Value
HostName
Specifies the SnapCenter database host name. If the SnapCenter database is hosted by a failover cluster instance (FCI), then specify the FCI owner host name.
true
true (ByPropertyName)
Path
Specifies the NetApp destination disk path where MySQL dumps are stored. Virtual disks are not supported.
true
Schedule
Specifies in a hash table the schedule to use when backing up the repository. For example: -Schedule @{"ScheduleType"="hourly";"StartTime"="10/21/2016 5:18 PM"}
true
RetentionCount
Specifies the number of backups to retain. By default, 7 backups are retained.
false
Example 1: Configuring a database backup for MySQL DB
 Protect-SmRepository -HostName NB-MVA-DEV057.nbsdsm.mycompany.netapp.in -Path E:\DATA -Schedule @{"ScheduleType"="hourly";"StartTime"="10/21/2016 5:18 PM"}
This example syntax configures an hourly backup for the file system specified and uses the Path argument to indicate the NetApp disk path where the repository DB dumps will be placed.
