Refresh-SmSnapLock
Updates the SnapLock settings for backups through ONTAP.
Syntax
Refresh-SmSnapLock [-AppObjectList] <String> [-All] <> [-Auth] <String>
Detailed Description
Updates the SnapLock settings for primary as well as secondary backups including SnapLock for SnapVault through ONTAP.
Name | Description | Required? | Pipeline Input | Default Value |
AppObjectList |
Object id list |
false |
true (ByPropertyName) |
All |
Refresh SnapLock Settings for all objects. |
false |
Auth |
Authentication |
false |
Example 1: Updates the SnapLock settings for all the resources in the SnapCenter Server
Refresh-SmSnapLock -All
This example syntax updates the SnapLock settings for all the resources in the SnapCenter Server through ONTAP.
Example 2: Updates the SnapLock settings by resource name
Refresh-SmSnapLock -AppObjectList R708202074BV1\SQL2019\MDSL_DB3
This example syntax updates the SnapLock settings by resource name through ONTAP.
Example 3: Updates the SnapLock settings by resource name list
Refresh-SmSnapLock -AppObjectList R708202074BV1\SQL2019\MDSL_DB1,R708202074BV1\SQL2019\MDSL_DB2
This example syntax updates the SnapLock settings by resource name list through ONTAP.
