SnapCenter cmdlets
Remove-SmAlert
Removes the alert(s) from SnapCenter.
Syntax
Remove-SmAlert [-AlertIds]  <String>  [-EntityType]  <SmEntityType>  [-EntityName]  <String>  [-Severity]  <SmAlertSeverity>
Detailed Description
Removes the alert(s) from SnapCenter. Either Alert Id(s) or Entity Type and Entity Name or Severity must be provided!
Name Description Required? Pipeline Input Default Value
AlertIds
Specify the list of alert ids to be deleted.
false
true (ByPropertyName)
EntityType
Specify the entity type of the alert(s) needs to be deleted. ("Server", "Host", "Storage")
false
EntityName
Specify the entity name of the alert(s) needs to be deleted.
false
Severity
Specify the severity of the alert(s) needs to be deleted. "Informational", "Warning", "Critical")
false
Example 1: Remove one or more alerts by id(s)
 Remove-SmAlert -AlertIds 100,101
This example syntax removes the specified alerts from SnapCenter.
Remove-SmAlert
Are you sure you want to remove the alert(s) ?
[Y] Yes [A] Yes to All [N] No [L] No to All [S] Suspend [?] Help (default is "Y"): y
Example 2: Remove one or more alerts by id(s) without confirmation dialogue
 Remove-SmAlert -AlertIds 100,101 -Confirm:$false
Example 1: Remove one or more alerts by EntityType and EntityName
 Remove-SmAlert -EntityType Host -EntityName mtme.englab.netapp.com
This example syntax removes all the alerts of the given Host.
Remove-SmAlert
Example 1: Remove one or more alerts by Severity
 Remove-SmAlert -Severity Warning
This example syntax removes all the warning alerts.
Remove-SmAlert
