SnapCenter cmdlets
Remove-SmBackup
Removes one or more backup.
Syntax
Remove-SmBackup [-BackupNames]  <String>  [-BackupIds]  <String>  [-DeleteSecondaryMetadata]  <>  [-CleanupSecondaryBackups]  <>  [-SourceVolumes]  <String>  [-CleanupBackups]  <>  [-Force]  <>  [-Auth]  <String>  [-AppObjectId]  <String>
Detailed Description
Name Description Required? Pipeline Input Default Value
BackupNames
Specifies the list of backup names to be deleted.
false
true (ByPropertyName)
BackupIds
Specifies the list of backup ids to be deleted.
false
Specifies that the secondary backup metadata should be deleted.
false
Specifies that the secondary backups that have no secondary Snapshot copies are cleaned up.
false
SourceVolumes
Specifies the source volumes whose secondary volumes are deleted. Use this option to clean-up the secondary backup metadata for the deleted volumes.
false
CleanupBackups
This cmdlet cleans up the backups that do not have Snapshot copies.
false
Force
Forces the removal of a backup.
false
Auth
false
AppObjectId
false
Example 1: Removing multiple backups using the backup ID
 Remove-SmBackup -BackupIds 3,4
This example syntax removes multiple backups using the backup IDs.
Remove-SmBackup
Are you sure want to remove the backup(s).
[Y] Yes [A] Yes to All [N] No [L] No to All [S] Suspend [?] Help (default is "Y"):
Example 2: Removing multiple backups using the backup name
 Remove-SmBackup -BackupNames "Payroll Dataset_vise-f6_08-04-2015_12.01.56.2744","Payroll Dataset_vise f6_08-04-2015_12.02.27.8732"
Remove-SmBackup
BackupResult : {}
Result   : SMCoreContracts.SMResult
TotalCount   : 0
DisplayCount : 0
Context  :
Job  : SMCoreContracts.SmJob
Example 3: Removing secondary backup metadata
 Remove-SmBackup -BackupIds 1 -DeleteSecondaryMetadata
This example syntax removes secondary backup metadata.
Remove-SmBackup
BackupResult : {}
TotalCount   : 0
DisplayCount : 0
Context  :
Example 4: Cleaning up secondary backups without a confirm dialogue
 Remove-SmBackup -CleanupSecondaryBackups -Confirm:$false
This example syntax cleans up secondary backups that do not have secondary Snapshot copies.
BackupResult : {}
TotalCount   : 0
DisplayCount : 0
Context  :
Example 5: Cleaning up secondary backups where secondary volume is deleted
 Remove-SmBackup -CleanupSecondaryBackups -SourceVolumes SVM1:Volume1,SVM2:Volume2
This example syntax cleans up the secondary backups that do not have any secondary snapshot copies or the secondary volumes are deleted for the specified source volumes.
BackupResult : {}
TotalCount   : 0
DisplayCount : 0
Context  :
