SnapCenter cmdlets
Remove-SmPermissionFromRole
Removes one or more permissions from a specified role.
Syntax
Remove-SmPermissionFromRole [-RoleName]  <String>  [-Permissions]  <String>
Detailed Description
Removes one or more permissions from a specified role. Use the format <SnapCenter Resource Name>:<Permission Name> where the SnapCenter Resource name is Dataset, Policy, Backup, Host, Storage Connection, Clone, Provision, Dashboard, Restore, Reports, Discovery, Plugin Install/Uninstall, Migration, Mount, and Unmount, and the permission name is create, read, update, delete and allow.
Name Description Required? Pipeline Input Default Value
RoleName
Specifies the name of the role from which you want to remove permissions.
true
true (ByPropertyName)
Permissions
Specifies one or more permissions you want to remove from a role. Use the format <SnapCenter Role Name>:<Permission Name>. Permission include: create, read, update, delete and allow.
true
Example 1: Removing a specific permission from a role
 Remove-SmPermissionFromRole -RoleName "Infrastructure Admin" -Permissions DataSet:create
This example syntax removes the specified permission from a role.
Are you sure you want to unassign the permission from role?.
[Y] Yes [A] Yes to All [N] No [L] No to All [S] Suspend [?] Help (default is "Y"): y
Example 2: Removing a specific permission from a role without a confirm dialogue
 Remove-SmPermissionFromRole -RoleName "Infrastructure Admin" -Permissions DataSet:create -Confirm:$false
Example 3: Removing multiple permissions from a role
 Remove-SmPermissionFromRole -RoleName "Infrastructure Admin" -Permissions("Host:read","Host:update","Host:delete")
This example syntax removes multiple permissions from a role.
