SnapCenter cmdlets
Remove-SmProtectResource
This command helps remove the protection for the resources.
Syntax
Remove-SmProtectResource [-Resources]  <Hashtable[]>  [-Force]  <>  [-UnmanageOnly]  <>
Detailed Description
Remove-SmProtectResource removes the protection for the resources provided.
Name Description Required? Pipeline Input Default Value
Resources
The list of protected resources from which protection will be removed.You must provide the resource information in a hashtable, and it must contain the resource name and type, as well as the host on which the resource is located. For example,@{"Host"="localhost";"Type"="SQL Database";"Names"="Instance\Database"}Valid Type values are: SQL Database, SQL Instance, SQL Availability Group.You can include comma-separated values for Names. For Oracle Database, the format is -Resources @{"Host"="host.example.com";"Oracle Database"="db1"}. For Oracle Application Volume, the format is -Resources @{"Host"="host.example.com";"Application Volume"="appVol1"}.
true
true (ByPropertyName)
Force
The force flag indicates that the protection will be deleted even if it has an associated policy and backup.
false
UnmanageOnly
false
Example 1: Removes the protection of the resources
 Remove-SmProtectResource  -Resources @{"Host"="test.mycompany.com";"Type"="SQLDatabases";"Names"="test\SQLExpress\inst1"},@{"Host"="test.mycompany.com";"Type"="SQLDatabases";"Names"="test\SQLExpress\inst2"}  -Force
This example syntax removes the protection of the two resources
Are you sure you want to delete the Protection of the selected resource?
[Y] Yes [A] Yes to All [N] No [L] No to All [S] Suspend [?] Help (default is "Y"):
Example 1: Removes the protection of the resources without confirmation dialogue
 Remove-SmProtectResource  -Resources @{"Host"="test.mycompany.com";"Type"="SQLDatabases";"Names"="test\SQLExpress\inst1"},@{"Host"="test.mycompany.com";"Type"="SQLDatabases";"Names"="test\SQLExpress\inst2"}  -Force -Confirm:$false
Example 3: Unprotecting a single volume
 Remove-SmProtectResource -Resources @{"Type"="StorageVolume";"ResourceGuids"="f37b4bae-72a2-48b3-8504-7cc8eef15031";}
Example 4: Unprotecting multiple volumes
 Remove-SmProtectResource -Resources @{"Type"="StorageVolume";"ResourceGuids"="f37b4bae-72a2-48b3-8504-7cc8eef15031,b806a86a-1374-4be1-bb83-fc0d33947a97";}
Example 5: Removes the protection of the Oracle Application Volume resources
 Remove-SmProtectResource -Resources @(@{"Host"="R8092776CF4V1.HNK2.com";"Application Volume"="appVol1"},@{"Host"="R8092776CF4V1.HNK2.com";"Application Volume"="appVol2"})
This example syntax removes the protection of the two Oracle application volume resources
