Remove-SmResourceCredentialName
Unregister a registered SQL instance credential.
Syntax
Remove-SmResourceCredentialName [-ResourceName] <String>
Detailed Description
Unregister a registered SQL instance credential based on the parameters provided.
| Name | Description | Required? | Pipeline Input | Default Value |
ResourceName |
true |
true (ByPropertyName) |
- Example 1: Removes a registered SQL instance credential by the SQL instance name. -
Remove-SmResourceCredentialName -ResourceName R708202074BV1\SQL2019
This example syntax removes a registered SQL instance credential based on the SQL instance name provided.
Are you sure you want to perform this action?
[Y] Yes [A] Yes to All [N] No [L] No to All [S] Suspend [?] Help (default is "Y"): Y
Example 2: Removes a registered SQL instance credential by the SQL instance name without a confirmation dialogue.
Remove-SmResourceCredentialName -ResourceName R708202074BV1\SQL2019 -Confirm:$false
