Reseed-SmDagReplicaCopy
This command will restore or reseed the failed copy of the database.
Syntax
Reseed-SmDagReplicaCopy [-ReplicaHost] <String> [-Database] <String> [-BackupHost] <String>
Detailed Description
Restores an unhealthy replica by using either the most recent copy on the same host or the most recent copy from an alternate host.
| Name | Description | Required? | Pipeline Input | Default Value |
ReplicaHost |
true |
false |
Database |
true |
false |
BackupHost |
false |
false |
Example 1: Reseed a replica
reseed-SmDagReplicaCopy -ReplicaHost "mva-rx200.netapp.com" -Database execdb -BackupHost "mva-rx201.netapp.com"
