SnapCenter cmdlets
Stop-SmJob
Stops a job that is in progress.
Syntax
Stop-SmJob [-JobId]  <Int32>
Detailed Description
Name Description Required? Pipeline Input Default Value
JobId
The ID associated with the job you want to stop.
false
false
Example 1: Stopping a job
 Stop-SmJob -JobId 1002
This example syntax stops a job for the job ID specified.
