Add-SmPermissionToRole
Adds one or more permissions to a specified role.
Syntax
Add-SmPermissionToRole [-RoleName] <String> [-Permissions] <String>
Detailed Description
Adds one or more permissions to a specified role. Use the format <SnapCenter Role Name>:<Permission Name> where the SnapCenter role name is Dataset, Policy, Backup, Host, Storage Connection, Clone, Provision, Dashboard, Restore, Reports, Discovery, Plugin Install/Uninstall, Migration, Mount, and Unmount, and the permission name is create, read, update, delete and allow.The following permissions have the Enabled attribute code: Install/Uninstall, Restore, Dashboard, Reports, and Discovery.For example, if you want to give Host create permissions, you would enter: Add-SmPermissionToRole -Permission Host:Create
| Name | Description | Required? | Pipeline Input | Default Value |
RoleName |
Specifies the name of the role to which you want to add permissions. |
true |
true (ByPropertyName) |
Permissions |
Specifies one or more permissions you want to add to a role. Use the format <SnapCenter Role Name>:<Permission Name>. Permissions include: create, read, update, delete and allow. |
true |
Example 1: Adding host read, update, and delete permissions to a role
Add-SmPermissionToRole -RoleName Admin -Permissions ("Host:read","Host:update","Host:delete")
This example syntax adds host read, update and delete permissions to the Admin role.
Example 2: Adding host create permissions to a role
Add-SmPermissionToRole -RoleName SnapCenterAdmin -Permissions Host:create
This example syntax adds host create permissions to the SnapCenterAdmin role.
SnapCenterAdmin
Host
Example 3: Adding dataset create permissions to a role
Add-SmPermissionToRole -RoleName SnapCenterAdmin -Permissions DataSet:create
This example syntax adds dataset create permission to the SnapCenterAdmin role.
SnapCenterAdmin
DataSet
