Get-SdInfo
Gets information about the SnapCenter Plug-in for Microsoft Windows instance that you are running.
Syntax
Get-SdInfo [-Session] <String> [-Host] <String> [-Details] <> [-Session] <String> [-Host] <String>
Detailed Description
You can use this cmdlet to retrieve the version number of the SnapCenter Plug-in for Microsoft Windows instance you are currently running. You can use the Details parameter to get additional information about Snapshot, discovery, virtualization, configuration, storage resolution, SMB shadow copy, SnapRemote, administration, and provisioning services, along with the interface name.
| Name | Description | Required? | Pipeline Input | Default Value |
Session |
Specifies the session ID from Open-SmConnection.. |
false |
true (ByPropertyName) |
Host |
Specifies the name or IP address of the host on which you execute the operation. The default is your local machine. |
false |
Details |
Gets additional information about Snapshot copy, discovery, virtualization, configuration, storage resolution, SMB shadow copy, SnapRemote, administration, and provisioning services, along with the interface name. |
false |
Example 1: Getting the details about the SnapCenter Plug-in for Microsoft Windows instance
PS C:\> Get-SdInfo -Details
This example gets detailed information about the version and services of the SnapCenter Plug-in for Microsoft Windows instance you are running.
Get-SdInfo -Details Version: 7.0.0.5779 Snapshot Service InterfaceName: SDSnapshot_v1_1 Version: 7.0.0.5779 URLForInterface: net.tcp://localhost:808/SnapDrive/Snapshot URLForWSDL: Discovery Service InterfaceName: SDDiscovery_v10 Version: 7.0.0.5779 URLForInterface: net.tcp://localhost:808/SnapDrive/Discovery URLForWSDL: Virtualization Service InterfaceName: SnapDrive.Nsf.Interfaces.Virtualization.IVirtualMachineManagement Version: 7.0.0.5779 URLForInterface: net.tcp://localhost:808/SnapDrive/Virtualization URLForWSDL: Configuration Service InterfaceName: SnapDrive.Nsf.Interfaces.SDConfiguraiton Version: 7.0.0.5779 URLForInterface: net.tcp://localhost:808/SnapDrive/Configuration URLForWSDL: StorageResolution Service InterfaceName: SnapDrive.Nsf.Interfaces.SDStorageResolution Version: 7.0.0.5779 URLForInterface: net.tcp://localhost:808/SnapDrive/StorageResolution URLForWSDL: CIFS ShadowCopy Service InterfaceName: SnapDrive.Nsf.Interfaces.SDCIFSShadowCopyManagement Version: 7.0.0.5779 URLForInterface: net.tcp://localhost:808/SnapDrive/CIFSShadowCopyManagement URLForWSDL: SnapRemote Service InterfaceName: SDSnapRemote_v1_3 Version: 7.0.0.5779 URLForInterface: net.tcp://localhost:808/SnapDrive/SnapshotRemote URLForWSDL: Administration Service InterfaceName: SDAdmin_v10 Version: 7.0.0.5779 URLForInterface: net.tcp://localhost:808/SnapDrive/SDAdminNext URLForWSDL: InterfaceName: SDAdmin Version: 7.0.0.5779 URLForInterface: net.tcp://localhost:808/SnapDrive/SDAdminInfo URLForWSDL: Provisioning Service InterfaceName: SnapDrive.Nsf.Interfaces.SDProvisioningManagement Version: 7.0.0.5779 URLForInterface: net.tcp://localhost:808/SnapDrive/ProvisioningManagement URLForWSDL:
