Set-SmDataCollectionEmsTarget
Specifies the target storage system to which you want to send your EMS data collection messages.
Syntax
Set-SmDataCollectionEmsTarget [-Target] <String>
Detailed Description
Specifies the target storage system to which you want to send your EMS data collection messages. You are not required to set up the EMS data collection target storage system. If you omit the EMS data collection target, SnapCenter sends the EMS storage collection messages to the first in your list of storage system connections, and retries subsequent connections upon failure.
| Name | Description | Required? | Pipeline Input | Default Value |
Target |
Specifies your target storage system name. If you need to identify the storage system name, run Get-SmStorageConnection to view a list of storage system names. |
true |
false |
Example 1: Setting the EMS data collection target storage system
Set-SmDataCollectionEmsTarget -Target SVM1
This example syntax sets the target storage system to which you want to send your EMS data collection messages.
Target
SVM1
