Set-SmResource
Modifies custom plug-in resource or an Oracle plug-in application volume resource settings.
Syntax
Set-SmResource [-UndoDeletion] <> [-ResourceId] <String> [-HostName] <String> [-PluginCode] <PluginCode> [-ResourceId] <String> [-HostName] <String> [-PluginCode] <PluginCode> [-RunAsName] <String>
Detailed Description
Used for modifying allowed attributes of a custom plug-in resource or an Oracle plug-in application volume resource. Also used for re-adding a resource that was soft deleted (resource which is protected).
| Name | Description | Required? | Pipeline Input | Default Value |
UndoDeletion |
false |
true (ByPropertyName) |
ResourceId |
: System-generated unique ID of a resource. For Oracle Application Volume Resource, its resource ID is of the format HostName\ResourceName. |
false |
HostName |
Specifies the name or IP address of the host, only when the Agent or Plugin parameters are specified. |
true |
PluginCode |
Specifies which plug-in configuration you want to modify. Possible inputs include MSFT_SQL, SCW, SCO, HANA and SCU. For example, for SnapCenter Plug-in for Microsoft SQL Server instances, the plug-in code is MSFT_SQL. |
true |
RunAsName |
false |
TenantDatabaseName |
This is a SAP HANA database specific parameter. It is the name of the tenant database. This parameter is deprecated for MultiTenant database container resources, it will be ignored and auto discovered internally. |
false |
TenantType |
This is a SAP HANA database specific parameter. This specifies the tenant type of SAP HANA Multitenant Database Container. SingleTenant as tenant type is deprecated.SingleTenant as tenant type is deprecated |
true |
MultiTenant |
Example 1: Modifying custom plugin DB2 resource
Set-SmResource -HostName 'sccorelinux188.sccore.test.com' -PluginCode 'DB2' -ResourceName Database1 -ResourceType Database -StorageFootPrint (@{"QTREE_NAME"="inventory_vol_sec";"VolumeName"="inventory_vol";"StorageSystem"="vserver_scauto_secondary"}) -Instance INST
Modify Storage footprint for Database of DB2 plug-in
Cmdlet Output: Successfully updated the resource
PluginName : DB2
Uid: INST\Database1
ParentUid :
SmAppFiles :
SmAppFileStorageGroups : {}
PluginParams : SMCoreContracts.SmKeyValueCollection
MountPaths :
LastBackupDate :
LastBackupStatus :
IsProtected: False
Type : Database
utoDatabase
Host : sccorelinux188.sccore.test.com
UserName :
Passphrase :
Deleted: False
Auth :
IsClone: False
CloneLevel : 0
Hosts :
Example 2: Modifying SAP HANA Multitenant Database Container
Set-SmResource -HostName 'scspr0204312001.gdl.englab.netapp.com' -ResourceId 'scspr0204312001.gdl.englab.netapp.com\hana\MDC\M01' -PluginCode' 'hana' -DatabaseName 'newname' -ResourceType 'MultipleContainers' -SID 'M01' -TenantType 'SingleTenant'
Modify DatabaseName for SAP HANA database of type MultipleContainers.
cmdlet Set-SmResource at command pipeline position 1
PluginName : hana
Uid: MDC\M01
ParentUid :
SmAppFiles :
MountPaths :
pluginConfiguration: SMCoreContracts.SmSCSAPHANAResourceParameters
LastBackupDate :
LastBackupStatus :
IsProtected: False
IsWindowsResource : False
Type : MultipleContainers
Host : scspr0204312001.gdl.englab.netapp.com
UserName :
Passphrase :
Deleted: False
Auth : SMCoreContracts.SmAuth
IsClone: False
CloneLevel : 0
Hosts :
StorageName:
ResourceGroupNames :
PolicyNames:
Key: 0
NsmObjectID: 0
Example 3: Undo SmResource deletion
Set-SmResource -HostName 'sccorelinux188.sccore.test.com' -PluginCode 'DB2' -ResourceName Database1 -UndoDeletion
Adds the deleted resource and is available for protection.
Example 4: Edit the database name and HDB Secure User Store Key for MultiTenant database container with multi tenants resource type.
Set-SmResource -HostName 'vp-hana2.gdl.englab.netapp.com' -PluginCode 'HANA' -DatabaseName MDC_MT_modified_again -ResourceType MultipleContainers -StorageFootPrint (@{'VolumeName'='VP_HANA2_data';'StorageSystem'='buck.gdl.englab.netapp.co'}) -sid 'A12' -userstorekeys 'A12KEY_modified_again' -TenantType 'MultiTenant'
This sets the database name and HDB Userstore Key for MultiTenant database container with multi tenants resource type.
PluginName : hana
Uid: MBC\A12
ParentUid :
SmAppFiles :
MountPaths :
LastBackupDate :
LastBackupStatus :
IsProtected: False
Host : vp-hana2.gdl.englab.netapp.com
UserName :
Passphrase :
Deleted: False
IsClone: False
CloneLevel : 0
Hosts :
StorageName:
PolicyNames:
Key: 0
NsmObjectID: 0
Example 5: Edit the database name and HDB User Store Key for single tenant resource type.
Set-SmResource -HostName 'vp-hana2.gdl.englab.netapp.com' -PluginCode 'HANA' -DatabaseName MDC_ST_modified -ResourceType MultipleContainers -StorageFootPrint (@{'VolumeName'='lun_vol';'StorageSystem'='10.232.206.5'}) -sid 'A12' -userstorekeys 'A12KEY_modified' -TenantType 'SingleTenant' -TenantDatabaseName 'TDB'
This sets the database name and HDB User Store Key for single tenant resource type. In this example, the tenant database name is required to edit the resource, which is added in SnapCener Server v4.2 or earlier.
PluginName : hana
Uid: TDB
ParentUid :
SmAppFiles :
MountPaths :
LastBackupDate :
LastBackupStatus :
IsProtected: False
UserName :
Passphrase :
Deleted: False
IsClone: False
CloneLevel : 0
Hosts :
StorageName:
PolicyNames:
Key: 0
NsmObjectID: 0
Example 6: Edit an Oracle Application Volume Resource storage footprint
Set-SmResource -HostName 'R8092776CF4V1.HNK2.com' -PluginCode 'SCO' -ResourceName appVol -StorageFootPrint @(@{"VolumeName"="vol_test1";"StorageSystem"="10.232.206.165"},@{"VolumeName"="vol_test2";"LunName"="lun_test2";"StorageSystem"="10.232.206.165"},@{"QtreeName"="qtree_test1";"VolumeName"="vol_test3";"StorageSystem"="10.232.206.165"})
This example modifies storage footprint of an Oracle Application Volume Resource
Set-SmResource
Are you sure you want to modify the resource : 'appVol' ?
[Y] Yes [A] Yes to All [N] No [L] No to All [S] Suspend [?] Help (default is "Y"): Y
Uid: appVol
SmAppFileStorageGroups : {, , }
IsProtected: False
LastBackupDate :
LastBackupStatus :
Type : Application Volume
Host : R8092776CF4V1.HNK2.com
UserName :
Passphrase :
Deleted: False
IsClone: False
CloneLevel : 0
Hosts :
StorageName:
PolicyNames:
Key: 0
NsmObjectID: 0
SizeOfSmObject :
Example 7: Edit hostname and resource name of an Oracle Application Volume Resource
Set-SmResource -HostName 'R809278EA03V1.HNK2.com' -PluginCode 'SCO' -ResourceName appVolModified -ResourceId R8092776CF4V1.HNK2.com\appVol
This example modifies hostname and resource name of an Oracle Application Volume Resource
Set-SmResource
Uid: appVolModified
IsProtected: False
LastBackupDate :
LastBackupStatus :
Host : R809278EA03V1.HNK2.com
UserName :
Passphrase :
Deleted: False
IsClone: False
CloneLevel : 0
Hosts :
StorageName:
PolicyNames:
Key: 0
NsmObjectID: 0
SizeOfSmObject :
Example 8: Undo soft deletion of an Oracle Application Volume resource
Set-SmResource -HostName 'R809278EA03V1.HNK2.com' -PluginCode 'SCO' -ResourceName appVol1 -UndoDeletion
Adds the deleted Oracle Application Volume resource and is available for protection.
