Add-SmHost
Registers a standalone host or cluster with SnapCenter.
Syntax
Add-SmHost [-HostType] <SmOperatingSystemType> [-HostName] <String> [-CredentialName] <String> [-Port] <UInt16> [-DoNotAddClusterNodes] <> [-SkipPreinstallChecks] <> [-Force] <>
Detailed Description
Registers a standalone host or cluster with SnapCenter. You must register hosts with SnapCenter. For example, SnapCenter must be registered before you can perform any data protection jobs. In addition, if no plug-ins are installed on the host you are adding, SnapCenter remotely deploys plug-ins, or upgrades the plug-ins as needed.
| Name | Description | Required? | Pipeline Input | Default Value |
HostType |
Specifies the operating system of the host you are adding. Valid values are AIX, Windows, Linux, and vSphere. The default value is Windows. If you are managing a Windows VM containing RDM or VMDK storage, ensure that you add the vSphere host before creating a backup. |
true |
true (ByPropertyName) |
HostName |
Specifies the name or IP of the cluster or standalone host you want to add. |
true |
CredentialName |
Specifies the name of the account that is required to perform application-specific operations in SnapCenter. You can use a credential account to perform application-specific operations within SnapCenter, such as remotely installing plug-ins. Use the Add-SmCredential cmdlet to create a credential account. |
false |
Port |
Specifies the port you want to use for SnapCenter to host agent communication. The default is 8145. Ensure that the firewall is open on both SnapCenter and the remote host to enable host agent communication. |
false |
DoNotAddClusterNodes |
Specifies not to include all nodes in the cluster. If you set the parameter to True, then only the specified host is added. The default value is False, which means that when you provide a cluster name, all nodes in the cluster are added and managed by SnapCenter. |
false |
False |
SkipPreinstallChecks |
Specifies that host registration prechecks will not be triggered. |
false |
Force |
Switch to disable validation of the host signature. |
false |
Example 1: Registering a host with SnapCenter
Add-SmHost -HostName C226030161613-1.srqatdom06.local -HostType Windows -DoNotAddClusterNodes -CredentialName admin
This example syntax registers the specified Windows host with SnapCenter.
OsInfo : SMCoreContracts.SmOperatingSystemInfo
HostName : C226030161613-1.srqatdom06.local
IP : 10.232.193.208,fd20:8b1e:b255:8029:19a0:6c5e:ae99:79e0
Description:
HostId : 5
DomainName : srqatdom06.local
Version:
Port :
ClusterHost: False
ClusterName:
Members: {}
HostStatus : eHostUp
HostPluginInfos: {}
ColoHost : False
HostConfiguration : SMCoreContracts.SmConfiguration
DiscoverPlugin : False
HostUUID :
HostBIOSID :
HostMaintenanceStatus : Production
IsNLBEnabled : False
VerificationServers:
HypervisorType :
IsHypervisorConfigured : False
Preference : 0
OverallStatus : SMCoreContracts.SmHostOverallStatusInfo
IsCatalogHost : False
Name :
Type :
Id :
Host :
UserName :
Passphrase :
Deleted: False
Auth : SMCoreContracts.SmAuth
IsClone: False
CloneLevel : 0
Hosts : {}
StorageName:
ResourceGroupNames :
PolicyNames:
Key: 0
NsmObjectID: 0
SizeOfSmObject :
Example 2: Registering a host where you deployed SnapCenter Plug-in for VMware vSphere OVA
Add-SmHost -HostType VSphere -HostName myHostname -CredentialName vmware_admin
This example syntax registers vSphere host with SnapCenter.
HostName : myHostname
IP : 10.225.97.14
Description:
HostId : 1
DomainName :
Version:
Port :
ClusterHost: False
ClusterName:
Members: {}
HostPluginInfos: {}
ColoHost : True
HostUUID :
HostBIOSID :
HypervisorType :
Preference : 0
Name :
Type :
Id :
Host :
UserName :
Passphrase :
Deleted: False
IsClone: False
CloneLevel : 0
Hosts : {}
StorageName:
PolicyNames:
Key: 0
NsmObjectID: 0
SizeOfSmObject :
Example 3: Registering an Exchange DAG with SnapCenter
Add-SmHost -HostName EXCH2016DAG -HostType Windows -CredentialName domain_admin -Verbose
This example syntax registers the specified Exchange DAG with SnapCenter.
Example 4: Registering an AIX host with SnapCenter
Add-SmHost -HostType AIX -HostName "aixhostname.fqdn.com" -CredentialName cred1
This example syntax registers the specified AIX host with SnapCenter.
HostName : aixhostname.fqdn.com
IP : 10.1.0.10
Description:
HostId : 79
DomainName : fqdn.com
Version:
Port :
ClusterHost: False
ClusterName:
Members: {}
HostPluginInfos: {}
ColoHost : True
HostUUID :
HostBIOSID :
HypervisorType :
Preference : 0
Name :
Type :
Id :
Host :
UserName :
Passphrase :
Deleted: False
IsClone: False
CloneLevel : 0
Hosts : {}
StorageName:
PolicyNames:
Key: 0
NsmObjectID: 0
SizeOfSmObject :
