Cancel-SmRestoreJob
Cancels the restore jobs, which are in queued state. This cmdlet also cancels the running SnapCenter Plug-in restore jobs.
Syntax
Cancel-SmRestoreJob [-JobId] <Int32>
Detailed Description
Enables you to cancel the queued restore jobs andthe running restore jobs for all the plug-ins.
Name | Description | Required? | Pipeline Input | Default Value |
JobId |
true |
false |
