SnapCenter cmdlets
Get-SdLunMap
Gets information about all the mapped LUNs and the igroups to which they are mapped.
Syntax
Get-SdLunMap [-StorageSystem]  <String>  [-LunPath]  <String>  [-Session]  <String>  [-Host]  <String>
Detailed Description
Name Description Required? Pipeline Input Default Value
StorageSystem
Specifies the storage system on which the igroup, to which you mapped your LUNs, is located.
true
true (ByPropertyName)
LunPath
Specifies the path of the LUN on your storage system.
false
Session
Specifies the session ID from Open-SmConnection.
false
Host
Specifies the name or IP address of the host on which you execute the operation. The default is your local machine.
false
