SnapCenter cmdlets
Get-SmRole
Get information for one or more RBAC roles.
Syntax
Get-SmRole [-Name]  <String>
Detailed Description
Get information about all the roles associated with SnapCenter. If you specify a specific role, you will return only information about the individual role.This information includes the role description, name.
Name Description Required? Pipeline Input Default Value
Name
Specifies the name of the role for which you want information. If you do not specify a role name, you will receive information for all available roles.
false
true (ByPropertyName)
Example 1: Getting information about all roles
 Get-SmRole
This example syntax retrieves the information about all SnapCenter roles.
Description : Overall administrator of SnapCenter system
Type: Administrator
Host:
UserName:
Passphrase  :
Deleted : False
Auth: SMCoreContracts.SmAuth
IsClone : False
CloneLevel  : 0
Description : Backup and Clone Viewer
Name: Backup and Clone Viewer
Type: Backup and Clone Viewer
Host:
UserName:
Passphrase  :
Deleted : False
IsClone : False
CloneLevel  : 0
Description : App Backup and Clone Admin
Name: App Backup and Clone Admin
Type: App Backup and Clone Admin
Host:
UserName:
Passphrase  :
Deleted : False
IsClone : False
CloneLevel  : 0
Description : Infrastructure Admin
Type: Infrastructure Admin
Host:
UserName:
Passphrase  :
Deleted : False
IsClone : False
CloneLevel  : 0
Example 2: Getting information about a specific role
 Get-SmRole -Name "Infrastructure Admin"
This example syntax retrieves the information about the specified role.
Host:
UserName:
Passphrase  :
Deleted : False
IsClone : False
CloneLevel  : 0
