SnapCenter cmdlets
Remove-SmReportSchedule
Delete a report schedule using this cmdlet.
Syntax
Remove-SmReportSchedule [-Name]  <String>
Detailed Description
Delete an existing report schedule using this cmdlet.
Name Description Required? Pipeline Input Default Value
Name
Specify the schedule name to delete it.
true
true (ByPropertyName)
Example 1: Delete a report schedule.
 Remove-SmReportSchedule -Name schedule1
This example deletes a report schedule. Pass the name of the schedule to delete it.
