Remove-SmUser
Removes AD users or local workgroup users from SnapCenter.
Syntax
Remove-SmUser [-UserName] <SmString> [-Domain] <String>
Detailed Description
Removes Active Directory users or local workgroup users from SnapCenter.
Name | Description | Required? | Pipeline Input | Default Value |
UserName |
Single user or list of users belonging to the same domain or workgroup. |
true |
true (ByPropertyName) |
Domain |
The domain to which the user belongs to. Workgroup users should skip this parameter. |
false |
Example 1: Removing a single user 1
Remove-SmUser -UserName user1 -Domain domain1
Example 2: Removing multiple users of same domainle 2
Remove-SmUser -UserName user1,user2 -Domain domain1
Example 3: Removing workgroup user
Remove-SmUser -UserName LocalUser1
