SnapCenter cmdlets
Rename-SmBackup
Renames an existing backup.
Syntax
Rename-SmBackup [-BackupName]  <String>  [-NewBackupName]  <String>  [-PluginType]  <PluginCode>
Detailed Description
Name Description Required? Pipeline Input Default Value
BackupName
Name of the existing backup.
true
false
NewBackupName
The new name you will give the backup.
true
false
PluginType
Provides the SnapCenter plug-in type. You can specify one of the following: SCSQL or SCW.
true
false
Example 1: Renames an existing backup
 Rename-SmBackup -BackupName SQL_DATASET_CLONE_csmdev-smsql-02_08-03-2015_13.45.19.4400
          -NewBackupName SQL_DATASET_CLONE_RENAMED -PluginType SCSQL -Verbose
This example command syntax renames an existing backup to a new name that you specify.
VERBOSE: Start Rename-SmBackup
VERBOSE: Rename-SmBackup ended successfully.
