Set-SmReportSchedule
Modify the report schedule using this cmdlet.
Syntax
Set-SmReportSchedule [-Name] <String> [-Plugin] <PluginCode> [-Enabled] <Boolean> [-ScheduleType] <String> [-DayOfTheWeek] <String> [-DayOfTheMonth] <String> [-TriggerTime] <String> [-DocumentType] <String> [-FromEmail] <String> [-Recipients] <String>
Detailed Description
Modify the report schedule by passing the required schedule name and the parameters. This command can be used to enable or disable a schedule.
| Name | Description | Required? | Pipeline Input | Default Value |
Name |
Specify the name of the schedule to be modified. |
true |
true (ByPropertyName) |
Plugin |
Specify the plug-in code to generate the report. For custom plug-ins, specify the custom plug-in name for example, hana, mysql. Specify 'all' to generate report for "All Plug-ins". |
true |
Enabled |
Specify the state as $true or 1 to enable the schedule and $false or 0 to disable the schedule. Disabled schedules will not be triggered. |
false |
ScheduleType |
Specify the schedule type. Valid values are 'daily', 'weekly', and 'monthly'. |
true |
DayOfTheWeek |
Specify the day of the week to run the schedule. Valid values are 'monday', 'tuesday', 'wednesday', 'thursday', 'friday', 'saturday', 'sunday'. This field is applicable only for weekly schedule. |
false |
DayOfTheMonth |
Specify the day (number) of the month to run the schedule. The value should be between 0 and 28. Enter zero to run the schedule for the last day of the month. This field is applicable only for monthly schedule. |
false |
TriggerTime |
Specify the TriggerTime HH:MM in 24 Hours format. |
true |
DocumentType |
Specify the format of the report to be sent over e-mail. The valid formats are PDF and CSV. Add the comma separator if both the formats are needed. |
true |
FromEmail |
Specify the e-mail address from which the report has to be sent. |
true |
Recipients |
Specify the e-mail address to send the report. For multiple e-mail ID's, seperate them by comma. |
true |
Example 1: Modifying plug-in of a report schedule.
Set-SmReportSchedule -Name schedule1 -Plugin SCO
This example modifies the plug-in of an existing schedule to 'SCO'. Plug-in value can be any specific plug-in or 'all'. Specify 'all', to generate the report for all the configured plug-ins. For the custom plug-ins specify the plug-in name instead of the plug-in code for example, hana, mysql.
Example 2: Modifying frequency of a report schedule.
Set-SmReportSchedule -Name schedule1 -ScheduleType weekly -DayOfTheWeek sunday -TriggerTime 1:10
This example modifies the frequency of an existing schedule to weekly. The ScheduleType, DayOfTheWeek/DayOfTheMonth, and TriggerTime constitutes a frequency, hence all these values should be specified to modify the frequency.
Example 3: Modifying From and Recipients e-mail id(s) of a report schedule.
Set-SmReportSchedule -Name schedule1 -FromEmail user@domain.com -Recipients "user1@domain.com,user2@domain.com"
This example modifies From and Recipients e-mail ids of an existing schedule. FromEmail can be any single valid e-mail id and Recipients can be a single or multiple comma separated e-mail ids.
Example 4: Disabling a report schedule.
Set-SmReportSchedule -Name schedule1 -Enabled $false
This example disables a report schedule. The parameter $true or 1 will enable the schedule and $false or 0 will disable the schedule. Disabled schedules will not be triggered.
