Set-SmSMTPServer
Specifies the SMTP server to use for sending data protection job reports to yourself or to others.
Syntax
Set-SmSMTPServer [-SMTPServerName] <String> [-EmailFrom] <String> [-EmailTo] <String> [-IsSendEmail] <> [-EmailSubject] <String>
Detailed Description
Specifies the SMTP server to use for sending data protection job reports to yourself or to others. The settings are applied globally for any SnapCenter job for which you configure email notification.
| Name | Description | Required? | Pipeline Input | Default Value |
SMTPServerName |
Specifies the name of the SMTP server. |
true |
true (ByPropertyName) |
EmailFrom |
Specifies the sender's email address. This parameter is required when you configure an SMTP server. |
true |
EmailTo |
Specifies the recipient's email address. This parameter is required when you configure an SMTP server. |
true |
IsSendEmail |
When specified, sends email to the SMTP server specified. This parameter is optional. |
false |
false |
EmailSubject |
Specifies the subject of the email. This parameter is optional. |
false |
false |
Example 1
Set-SmSMTPServer smtp.gdl.englab.netapp.com -EmailFrom zhimao@netapp.com -EmailTo zhimao@netapp.com -IsSendEmail -EmailSubject Hello
