Update-SmServerCluster
Updates the High Availability cluster configuration on the SnapCenter Server
Syntax
Update-SmServerCluster [-Credential] <PSCredential> [-ClusterNameString] <String> [-ClusterIPString] <String>
Detailed Description
Updates the High Availability cluster configuration on the SnapCenter Server. This can be used to update the cluster name or cluster IP Address.
| Name | Description | Required? | Pipeline Input | Default Value |
| Credential | Provides domain user credentials for the user to update High Availability cluster configuration. | true | true (ByPropertyName) | |
| ClusterName | F5 cluster name. | false | false | |
| ClusterIP | F5 Cluster IP Address. | true | false |
Example 1: Updates High Availability cluster configuration on the SnapCenter Server
Update-SmServerCluster -Credential sddev\administrator -ClusterName Sab_Pool_Update -ClusterIP 10.225.231.160
This example updates the High Availability cluster configuration on the SnapCenter Server.
Name: Modify High Availability for SnapCenter Server Configuration
StartTime   : 10/7/2019 3:31:55 AM
EndTime :
IsCancellable   : False
IsRestartable   : False
IsCompleted : False
IsVisible   : True
IsScheduled : False
PercentageCompleted : 0
Description :
Status  : Running
Owner   :
Error   :
Priority: None
Tasks   : {Update HA Parameters in SC Repository}
ParentJobID : 0
EventId : 0
JobTypeId   : 38
ApisJobKey  :
ObjectId: 0
PluginCode  : NONE
PluginName  : NONE
HostId  : 0
RoleId  :
JobIds  : {}
Monitor the progress of job 59 in the Job Monitor page or by running the cmdlet: 'Get-SmJobSummaryReport -JobId 59'
 PDFs
PDFs
