Authentication methods for SnapCenter credentials
Credentials use different authentication methods depending on the application or environment. Credentials authenticate users so they can perform SnapCenter operations. You should create one set of credentials for installing plug-ins and another for data protection operations.
Windows authentication
The Windows authentication method authenticates against Active Directory. For Windows authentication, Active Directory is set up outside of SnapCenter. SnapCenter authenticates with no additional configuration. You need a Windows credential to add hosts, install plug-in packages, and schedule jobs.
Untrusted domain authentication
SnapCenter allows users and groups belonging to untrusted domains to create Windows credentials. For the authentication to succeed, you should register the untrusted domains with SnapCenter.
Local workgroup authentication
SnapCenter allows the creation of Windows credentials with local workgroup users and groups. The Windows authentication for local workgroup users and groups does not happen during Windows credential creation but is deferred until the host registration and other host operations are performed.
SQL Server authentication
The SQL authentication method authenticates against a SQL Server instance. This means that a SQL Server instance must be discovered in SnapCenter. Therefore, before adding a SQL credential, you must add a host, install plug-in packages, and refresh resources. You need SQL Server authentication to perform operations such as scheduling on SQL Server or discovering resources.
Linux authentication
The Linux authentication method authenticates against a Linux host. You need Linux authentication during the initial step of adding the Linux host and installing the SnapCenter Plug-ins Package for Linux remotely from the SnapCenter GUI.
Non-root users must have execute permissions to run Java. |
AIX authentication
The AIX authentication method authenticates against an AIX host. You need AIX authentication during the initial step of adding the AIX host and installing the SnapCenter Plug-ins Package for AIX remotely from the SnapCenter GUI.
Oracle database authentication
The Oracle database authentication method authenticates against an Oracle database. You need an Oracle database authentication to perform operations on the Oracle database if the operating system (OS) authentication is disabled on the database host. Therefore, before adding an Oracle database credential, you should create an Oracle user in the Oracle database with sysdba privileges.
Oracle ASM authentication
The Oracle ASM authentication method authenticates against an Oracle Automatic Storage Management (ASM) instance. Oracle ASM authentication is required if you need to access an Oracle ASM instance and OS authentication is disabled on the database host. Before adding an Oracle ASM credential, create an Oracle user with system privileges in the ASM instance.
RMAN catalog authentication
The RMAN catalog authentication method authenticates against the Oracle Recovery Manager (RMAN) catalog database. If you have configured an external catalog mechanism and registered your database to catalog database, you need to add RMAN catalog authentication.
