SnapCenter software
Quick start for SnapCenter software
Contributors netapp-soumikd
The quick start guide outlines the basic steps to install and configure the SnapCenter software.
One Prepare for installing SnapCenter Server
You should ensure that all the requirements to install the SnapCenter Server are met.
Two Install SnapCenter Server
The SnapCenter Server can be installed on either Windows or Linux hosts. Download the SnapCenter Server installation package from the NetApp Support Site and execute the installer.
Three Configure SnapCenter Server
After installing the SnapCenter Server, you should configure it based on your environment.
Four Install the plug-in for your application
Ensure that all requirements for installing the application-specific plug-in are fulfilled based on the application in use, then proceed with installing the respective plug-in.
Five Protect your application
After successfully installing the SnapCenter Server and the necessary plug-ins, you can initiate the creation of application backups. These backups can later be utilized for restoration and cloning purposes when required.
