Automatic detection of host entities
Download PDF of this page
SnapDrive for UNIX automatically detects the configuration of the host entity for some commands. A few snap storage commands need only the name of the host entity. In these cases, you do not have to specify the type of the host entity.
The following commands are enabled for automatic detection:
storage delete -
storage resize -
snap create -
snap restore -
snap connect -
snap list
When the host entity exists, SnapDrive for UNIX automatically detects the type of the host entity. In this case, you need to provide only the name of the host entity; you do not have to specify the type. The SnapDrive snap commands and some storage commands also need only the name of the host entity; you do not have to specify the type.
Automatic detection of commands takes extra time for SnapDrive 4.1 and later because it collects the details of all the storage resources. If you want a faster response, specify the file specification with the SnapDrive for UNIX commands.
You can enable automatic detection for the storage delete operation by running the snapdrive storage delete command.
Example 1:
snapdrive storage delete host_dg my_fs -full
In the example, host_dg and my_fs are automatically detected.
Example 2:
snapdrive storage delete mydg -fs myfs -full
In the example, the mydg disk group is automatically detected.
You can enable automatic detection for the storage resize operation by running the snapdrive storage resize command.
For example:
[root@lnx197-132 ~]# snapdrive storage resize mydg23 -addlun -growby 10m
Auto detecting the type of filespec 'mydg23' in progress ... detected as disk group
discovering filer LUNs in disk group mydg23...done
LUN bart:/vol/voldm/mydg23-1_SdLun ... created
mapping new lun(s) ... done
discovering new lun(s) ... done.
initializing LUN(s) and adding to disk group mydg23...done
Disk group mydg23 has been resized
You can enable the automatic detection for the snap create operation by running the snapdrive snap create command.
For example:
root@lnx197-132 ~]# snapdrive snap create mydg22 mydg23 /mnt/mnt12 -snapname new_snap
Auto detecting the type of filespec 'mydg22' in progress ... detected as disk group
Auto detecting the type of filespec '/mnt/mnt12 ' in progress ... detected as file system
Starting snap create /dev/mapper/mydg22, /dev/mapper/mydg23, /mnt/mnt12
WARNING: DO NOT CONTROL-C!
If snap create is interrupted, incomplete snapdrive
generated data may remain on the filer volume(s)
which may interfere with other snap operations.
Successfully created snapshot new_snap on bart:/vol/voldm
snapshot new_snap contains:
disk group mydg22
disk group mydg23
disk group dg121 containing host volumes
lv121 (filesystem: /mnt/mnt12)
You can enable automatic detection for the snap connect operation by running the snapdrive snap connect command.
For example:
[root@lnx197-132 ~]# snapdrive snap connect mydg22 xxx mydg23 yyy -snapname bart:/vol/voldm:snap_1
Auto detecting the type of filespec 'xxx' in progress ...
xxx does not exist - Taking xxx as a destination to fspec mydg22Auto detecting the type of filespec 'mydg23' in progress ... detected as disk group
Auto detecting the type of filespec 'yyy' in progress ...
yyy does not exist - Taking yyy as a destination to fspec mydg23
connecting mydg22:
LUN copy mydg22_SdLun_0 ... created
(original: bart:/vol/voldm/mydg22_SdLun)
connecting mydg23:
LUN copy mydg23_SdLun_1 ... created
(original: bart:/vol/voldm/mydg23_SdLun)
Importing xxx, yyy
Successfully connected to snapshot bart:/vol/voldm:snap_1
disk group xxx
disk group yyy
You can enable the automatic detection for the snap restore operation by running the snapdrive snap restore command.
For example:
snapdrive snap restore bart:/vol/voldm/lun44 /mnt/fs3 fs5_SdDg/fs5_SdHv fs4_SdDg -snapname bart:/vol/voldm:toi_snap
Auto detection of file_spec(s) in progress ...
- 'bart:/vol/voldm/lun44' detected as LUN.
- '/mnt/fs3' detected as file system.
- 'fs5_SdDg/fs5_SdHv' detected as logical volume.
- 'fs4_SdDg' detected as disk group.
Starting to restore /dev/mapper/fs4_SdDg, /mnt/fs3, /dev/mapper/fs5_SdDg-fs5_SdHv, bart:/vol/voldm/lun44
WARNING: This can take several minutes.
DO NOT CONTROL-C!
If snap restore is interrupted, the filespecs
being restored may have inconsistent or corrupted
data.
For detailed progress information, see the log file /var/log/sd-recovery.log
Importing fs4_SdDg, fs3_SdDg, fs5_SdDg
Successfully restored snapshot toi_snap on bart:/vol/voldm
disk group fs4_SdDg containing host volumes
fs4_SdHv (filesystem: /mnt/fs4)
disk group fs3_SdDg containing host volumes
fs3_SdHv (filesystem: /mnt/fs3)
disk group fs5_SdDg containing host volumes
fs5_SdHv (filesystem: /mnt/fs5)
raw LUN: bart:/vol/voldm/lun44
SnapDrive does not support automatic detection for snap connect and snap restore operations for incorrect file specification.
You can enable automatic detection for the snap list operation by running the snapdrive snap list command.
For example:
root@lnx197-132 ~]# snapdrive snap list -snapname bart:/vol/voldm:snap_1 snap name host date snapped -------------------------------------------------------------------------------- bart:/vol/voldm:snap_1 lnx197-132.xyz.com Apr 9 06:04 mydg22 mydg23 dg121 [root@lnx197-132 ~]# snapdrive snap list mydg23 Auto detecting the type of filespec 'mydg23' in progress ... detected as disk group snap name host date snapped -------------------------------------------------------------------------------- bart:/vol/voldm:snap_1 lnx197-132.xyz.com Apr 9 06:04 mydg22 mydg23 dg121 bart:/vol/voldm:all lnx197-132.xyz.com Apr 9 00:16 mydg22 mydg23 fs1_SdDg bart:/vol/voldm:you lnx197-132.xyz.com Apr 8 21:03 mydg22 mydg23 bart:/vol/voldm:snap_2 lnx197-132.xyz.com Apr 8 18:05 mydg22 mydg23
Edit on GitHub
