Connecting to multiple filespecs
You can connect to multiple filespecs that reside in a volume. The following example describes how you can complete this operation.
For creating restricted FlexClone, you need to set the san-clone-method=unrestricted in the snapdrive.conf file or give `-clone unrestricted before you can connect to multiple filespec. This example displays the results when you want to connect to multiple filespec /mnt/fs_1 and /mnt/fs_2 in snap1 which reside in volume vol1.
The layout of /mnt/fs_1 and /mnt/fs_2 is given in the following:
# snapdrive storage show -fs /mnt/fs_1 /mnt/fs_2 -capabilities raw device: /dev/sdc1 mount point: /mnt/fs_1 (persistent) fstype ext3 allowed operations: all device filename adapter path size proto state clone lun path backing snapshot ---------------- ------- ---- ------ ----- ----- ------- ---------------- ---------------- /dev/sdc - P 100m iscsi online No homer:/vol/vol1/lun1 - raw device: /dev/sdo1 mount point: /mnt/fs_2 (persistent) fstype ext3 allowed operations: all device filename adapter path size proto state clone lun path backing snapshot ---------------- ------- ---- ---- ------- ----- ----- -------- ---------------- /dev/sdo - P 100m iscsi online No homer:/vol/vol1/lun2 -
Here the user used Snapshot snap2 which contains application consistent Snapshots of /mnt/fs1 and /mnt/fs2 for snap connect.
# snapdrive snap connect -fs /mnt/fs_1 -fs /mnt/fs_2 -snapname homer:/vol/vol1:snap2 -autorename -clone unrestricted
connecting /mnt/fs_1:
creating unrestricted volume clone homer:/vol/Snapdrive_vol1_volume_clone_from_snap2_snapshot ... success
mapping new lun(s) ... done
connecting /mnt/fs_2:
discovering new lun(s) ... done
Successfully connected to snapshot homer:/vol/vol1:snap2
file system: /mnt/fs_1_0
file system: /mnt/fs_2_0
Here, SnapDrive for UNIX has created a single unrestricted FlexClone Snapdrive_vol1_0_volume_clone_from_snap2_Snapshot from Snapshot snap2. This is then connected to LUN testlun1 and testlun2 to create a cloned host file system /mnt/fs1_0 and /mnt/fs2_0 respectively.
# snapdrive storage show -fs /mnt/fs_1_0 /mnt/fs_2_0 -capabilities raw device: /dev/sde1 mount point: /mnt/fs_1_0 (persistent) fstype ext3 allowed operations: all device filename adapter path size proto state clone lun path backing snapshot ---------------- ------- ---- ---- ----- ----- ----- -------- ---------------- /dev/sde - P 100m iscsi online flex-clone homer:/vol/Snapdrive_vol1_volume_clone_from_snap2_snapshot/lun1 vol1:snap2 raw device: /dev/sdac1 mount point: /mnt/fs_2_0 (persistent) fstype ext3 allowed operations: all device filename adapter path size proto state clone lun path backing snapshot ---------------- ------- ---- ---- ----- ----- ----- -------- ---------------- /dev/sdac - P 100m iscsi online flex-clone homer:/vol/Snapdrive_vol1_volume_clone_from_snap2_snapshot/lun2 vol1:snap2
